Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Cursor sensitivity
Cursor moves too slow or too fast.
DPI (dots per inch) too low or high
Adjust the DPI button on the mouse until a desired sensitivity is found. You may also adjust it in the driver software window.
Noisy movement
When moving mouse side to side, there is clacking sound.
Loose scroll wheel
Consider replacing with a slightly wider rubber wheel, using this guide if necessary.
Rough movement
It is difficult to slide the mouse side to side, often feels as if it catches on something.
Mouse feet need replacing
Sticker-like feet on the bottom of the mouse may be dirty or need replacing.
Connectivity issues
Cursor does not move when you move the mouse or scroll wheel.
Blockage of sensor
Clean the sensor area with a microfiber cloth or pick out debris with tweezers. Also, if for the hard to reach areas you can use a dust sprayer to get into the corners.
Out of date firmware
Check the Logitech website for updates to the firmware, consider enabling automatic updates. Without these updates you are unable to access any of Logitech's great new features that they offer.
Surface under mouse
The sensor may not be able to track properly on some surfaces, such as glass. Consider using a mouse pad. Having a mouse pad protects your mouse from any bumpy or transparent surfaces.
Author
with
Sage Farray
553 Reputation
3 Guides authored
UW Tacoma, Team S3-G1, Liner Spring 2017 Member of UW Tacoma, Team S3-G1, Liner Spring 2017
UWT-LINER-S17S3G1
4 Members
36 Guides authored
3 Comments
Just got a logitech G502 and I started noticing it would freeze for very short periods of time (~ 0.5sec freezes every 10-30 minutes. ) I tried different USB ports, different computer, redownloading drivers, uninstalling logitech gaming software, and it still randomly freezes. Looked online and other people having the same problem with no clear solution. This seems like a common thing with the G502
Gooblord - Reply Share
Currently having a problem with th left click button where it would not stay held down. Not sure what happened
BIV-DA- DOMANATOR - Reply Share
device turned off suddenly, laptop is not picking it up anymore, I have tried all the usb ports, even in another laptop, any suggestions?
Gus - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 54
All Time: 6,773
