Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Tablet won’t turn on
The tablet will not turn on. Screen remains dark.
Drained battery
If your tablet won't turn on and hasn’t been used in a while, you may simply have a drained battery. Plug your Lenovo TAB 4 8 into a wall outlet using the given charger and adaptor. Using a different, or off-brand, the charger could damage the device/battery. Let the tablet charge for 10 minutes, and try again.
Bad battery
If the tablet will not hold a charge, the battery must be replaced. Please refer to the battery replacement guide.
Faulty motherboard
If changing the battery did not solve the problem, you might have a faulty motherboard. Refer to the motherboard replacement guide.
Rear camera will not focus
The camera cannot take clear pictures.
Check the lens
Make sure the lens are clear from any dirt or residue.
Faulty rear camera
If the lens are clear and clean from the outside and the rear camera still does not want to focus and take clear pictures, the rear camera itself may have to be replaced. You can find instructions on how to replace the rear camera on a Lenovo Tab 4 8 here.
MicroSD card is not being recognized
Your Lenovo TAB 4 8 does not recognize or read your microSD card.
Remove microSD card
If your card is not being recognized or read by your Lenovo Tab 4 8, remove your microSD card and check to see if there is any obstruction or debris in the card reader. Once clear, reinsert your microSD card into the reader.
Re-format microSD card using a computer
Some microSD cards are not compatible because of its format. To format, you can use a computer to format it by following the instruction on this link:
Replace microSD card reader
If by formatting or trying a different microSD card does not solve the issue, then the microSD card reader may need to be replaced. You can find instructions on how to replace the microSD card reader on a Lenovo Tab 4 8 here.
Vibration does not work
When typing, the vibration does not function like before or not at all.
Replace vibrator
After making sure that the correct settings for vibration are on, and there is still vibration issues, you have a faulty vibrator. You can find instructions on how to replace the vibrator on a Lenovo Tab 4 8 here.
No audio when connecting to audio jack
No audio playing when connected to audio jack.
Check audio jack
If your working headphones you are connecting to the Lenovo Tav 4 8 are not playing audio, disconnect them and check to see if there is any obstruction in the audio jack. Use cotton swabs and a small amount of isopropyl alcohol to clear any debris from the headphone jack.
6 Comments
Tablet won’t turn off or turn on. Display shows a figure laying on his side with caption “Fastboot”???
Jerry Moore - Reply Share
Long hold power button
Vijay Khurana - Reply Share
Long hold vol. down button + Power button at the same time.
ธนาคม เร่งเพียร - Reply Share
Pls help me it's a new one but start my tab and stay in black screen
BirukZ 2023 - Reply Share
Camer is not working.
Hirko Abraham - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 44
All Time: 2,906
