Excessive/Deficient Exposure with the Flash
The flash is causing photos to be too exposed or not exposed enough.
Issues with the Capacitor
If worse has come to worst, you might have a capacitor problem. Either the capacitor inside of your flash has become corrupted or the parallel plates of the capacitor have shifted and the flash is unable to properly hold charge. Either way, you're going to need to replace it. Repairing the initial capacitator is much too tedious and time consuming, so you're better off with simply exchanging the gadget.
Replacing Battery
If your flash isn't functioning because your battery is dead, this can only mean one thing: the whole camera isn't functioning. Although this sounds bad, the solution is rather simple; all you need to do is replace the battery! See? Not too hard, and your camera should be up-and-running in no time.
Replacing Flash Diffuser
If your flash diffuser (that thingy that covers the flash's light bulb) is cracked, you could be leaking more light onto your subject than you want. As a result, this is a major cause of overexposure. As a warning, this fix may be a bit tedious; only attempt this if you really want it fixed!
Changing the Bulb
The bulb on your flash has finally died out. Now what? [invalid guide link] it!
Make-shift Alternatives
Rather than invading the sanctity of your precious camera's body, you can also try makeshift solutions for overexposure due to the camera flash. For those of you searching for a quick fix, or are afraid of tampering with your prized little Leica, we offer incredibly easy and effective solutions just for you. The simplest would be to tape a piece of thin tissue paper over the flash to act as an additional flash diffuser. Alternatively, using a piece of regular paper to cover half or three-quarters of the flash would greatly reduce the risk of overexposure. A little creativity can go a long way to saving your camera from a bad flash!
Lens Cover is Cracked or Damaged
The lens cover has been damaged or destroyed and no longer covers the front lens when the camera is turned off.
Replacing the Cover
If you've cracked or damaged your lens cover, there's really only one thing you can do: replace it. Unless you're a camera repair professional, the only realistic solution is to purchase another lens cover and switch the two.
Camera Will Not Zoom or Focus
When trying to zoom or focus on a subject, the camera will not cooperate.
Replacing the Motor
If you're having trouble focusing or zooming, there may be a motor dysfunction. If you're having trouble with your zoom motor it might need to be replaced. Alternatively, your focus motor might be having problems, and that too can be replaced. The motors are too delicate to be handled without a professional, so the only true option is to replace them.
Cleaning the Lens
If your photos are coming out hazy, odds are you might have smudged up the lens a bit. To prevent blurring the lens, there are guidelines for how-to properly grasp the camera. But even if you're fingers end up slipping and smearing the lens, no worries. This is an easy fix, just clean it!
Zoom Buttons Need Replacing
Underneath that button that says "W" and "T", there are little sensors that detect whether you want to go wide or telephoto for zooming. If one of those sensors splits, the zoom won't work! Best solution: replace it.
Camera Develops Obscure or Cloudy Photographs
Photographs are cloudy or obscure.
Opening the Door While Undeveloped Film is Still Exposed
Film is highly sensitive to light. Opening the back door while there is unexposed film behind it could cause your photos to be overexposed by the sun's harsh rays and ruin your family's vacation memories! Luckily, Leica has equipped the Z2X with a novel invention: the mid-roll rewind function. This button allows you to retract the film to protect those precious, unexposed shots.
Film will not Rotate Properly
The film will not progress onto the next exposure properly.
Motor Needs Replacing
After you take a shot, if you've got a feeling that the film just isn't progressing to the next exposure, you might have a motor malfunction. Once again, motors are incredibly fragile so manually fixing these gizmos is not an option. Your solution? Replace it.
Film Installation
Putting film into a camera seems like a pretty tricky process, but once you've got the hang of it, it should be no problem! Follow these simple steps and you'll be installing film like tying your shoes.
Tripod Plate Won't Screw into Camera Body
The screw on the tripod plate will not stay in the camera body after you attempt to screw it in.
Replacing the Socket
If you're trying to put your camera on a tripod, but it won't screw in right, you might have stripped the tripod socket on the underside of the camera. Luckily, this part is very easy to replace.
Battery Has Become Corroded
The battery has been corroded and there is battery acid everywhere.
Cleaning and Disposing the Battery
Proper cleansing and maintenance of your camera is very important. If your battery happens to explode, you'll want to clean it up the right way! Not to mention, there are several ways to go green with battery recycling.
Battery Door Will Not Fasten
The battery door, when you try to close up the body, will not completely close and fasten shut.
Hinge Reparation
The hinges on the door are what allows you to open and close the back door with the greatest of ease. If these hinges break, you could have quite a difficult time keeping light sealed out from the unexposed film inside. Your best bet here is to repair the hinges. Side note: it's the little things that make all the difference.
Latch Needs Fixing
The latch on the door holds the door tight against the body of the camera. If this is broken, light will leak in and destroy your photos. If this is the case, the latch needs to be fixed. Minor technicalities can make a huge impact.
Mid-roll Rewind Not Working
The rewind function is not working properly.
Motor Replacement
If you press the rewind function and feel like it's not doing its job, the film motor may be dysfunctional. Given that this is the problem, it needs to be replaced. Unfortunately, this is the only convenient solution for motor damage or dysfunction.
Kenny
57 Reputation
3 Guides authored
Cal Poly, Team 18-19, Garner Spring 2011 Member of Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Members
60 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 78
All Time: 3,211
