Up to 20% off select tools
Leica Z2X Flash Diffuser Replacement
Views: 4.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
103
All Time:
4,300
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 - 45 minutes
Difficulty: Very difficult
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the Flash Diffuser.
    1. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Screws: step 1, image 1 of 1
      • Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
      • There is a screw located inside of the tripod hole (large circle.) Make sure the screw is removed from there too!
      Ask FixBot
    2. Leica Z2X Flash Diffuser Replacement, Open the Back Door: step 2, image 1 of 1
      • Open the back door on the camera by pushing down on the door latch.
      Ask FixBot
    3. Leica Z2X Flash Diffuser Replacement, Remove the Bottom Plate: step 3, image 1 of 1
      • Apply pressure to the bottom plate and it will pop off.
      • From here, you can replace the bottom plate, or continue on to further steps.
      Ask FixBot
    1. Leica Z2X Flash Diffuser Replacement, Flash Diffuser: step 4, image 1 of 1
      • Now that you've removed the bottom plate, you can pull apart the front and back covers.
      • Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
      Ask FixBot
    2. Leica Z2X Flash Diffuser Replacement: step 5, image 1 of 1
      • Next, the back cover.
      • Apply pressure to remove the back plate.
      • Be careful of the buttons on the top of the camera falling off, they are small parts and CAN get lost easily.
      • The best way to remove the back is to stick your thumbs on either side of the battery socket and separate from there.
      Ask FixBot
    3. Leica Z2X Flash Diffuser Replacement: step 6, image 1 of 1
      • You should now have removed the front and back plates.
      Ask FixBot
    4. Leica Z2X Flash Diffuser Replacement: step 7, image 1 of 1
      • Removing the flash diffuser should be simple from here.
      • Simply take the front cover and apply pressure to the front of the flash diffuser and it should pop right out.
      Ask FixBot
Author
with
Kenny
57 Reputation
3 Guides authored
Cal Poly, Team 18-19, Garner Spring 2011 Member of Cal Poly, Team 18-19, Garner Spring 2011
CPSU-GARNER-S11S18G19
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 103
All Time: 4,300
