Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
LG Thrill 4G Won't Turn On
No matter how many times you try, your smartphone will not turn on or at best will boot up to the LG Logo screen, but no further.
Battery Out of Charge
Plug your phone in for a few hours. If after a few hours your phone has less than 30% charge, your phone will not turn on.
Bad Battery
Open back cover and locate old battery to be replaced with new battery. You can find instructions on how to perform this task in the following guide. Make sure to charge new battery before attempting to turn phone on again.
LG Thrill 4G Screen Not Working
Display will not work or is not viewable.
Screen Won't Display Anything
After pushing the on button, your phone starts up but wont display anything. You may have a software problem.
Screen is Broken
Your phone is turned on and the screen has multiple cracks impeding the display of the phone.
LG Thrill 4G Camera Doesn't Work
No matter how many times you attempt to take successful pictures, your camera just won't work.
Camera Shows Black Screen
When attempting to take pictures your camera shows a black screen. This problem is due to a software issue within the phone.
Camera is Broken
Your camera does not work at all or is cracked, leaving blurry or unclear pictures.
LG Thrill 4G Buttons Don't Work
Buttons are Stuck
When pressing the power, camera, or volume buttons, nothing happens on the display of the phone. Jiggle the buttons around to see if the problem becomes resolved. If not, the following guide will show you how to change the buttons on the LG Thrill 4G.
Buttons are Broken or Missing
The buttons on the phone are cracked or completely gone. The following guide will show you how to change the buttons on the LG Thrill 4G.
Memory Card Unrecognized
Your device is unable to access the information stored on the SD card.
Card is Loose
Remove the SD card from the SD card slot, then replace the SD card firmly within the slot.
Bad SD Card
The SD card that is being used is corrupt. Replace old SD card with new SD card.
Software Bug
If the SD card is not the problem, then there may be a software bug. Make sure your phone is updated to the most recent software.
Internal Component Damage
If the SD card is not the problem, and neither is a software bug, then there may be a damaged internal component. The two internal components that may be damaged include the SD/Sim card board and the motherboard. Click on the following links to view the replacement guides for both components.
Speaker Not Working
The speaker on the phone does not produce sound or only produces a static sound.
Speaker Doesn't Produce Sound
The speaker on your phone doesn't play music, videos, or notifications. The following guide will show you how to replace the LG Thrill 4G's speaker.
Speaker Only Produces Static
The speaker on the LG Thrill 4G only makes static noise when on. To replace the speaker, follow this speaker guide for replacement.
Author
with
Kenny Richmond
260 Reputation
2 Guides authored
USF Tampa, Team 1-6, Blackwell Winter 2015 Member of USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Members
60 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 963
