LG Thrill 4G SIM/Micro SD Card Replacement
    1. LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: step 1, image 1 of 2 LG Thrill 4G SIM/Micro SD Card Replacement, Back Cover Removal: step 1, image 2 of 2
      • Pry open the back cover by using a fingernail or a plastic opening tool.
      • There is a small notch at the bottom of the cover for easy removal.
      Ask FixBot
    2. LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: step 2, image 1 of 2 LG Thrill 4G SIM/Micro SD Card Replacement, Battery Removal: step 2, image 2 of 2
      • Remove the battery from the phone.
      • There is a small ledge located at the bottom of the battery for easy removal.
      Ask FixBot
    1. LG Thrill 4G SIM/Micro SD Card Replacement, Screw Removal: step 3, image 1 of 1
      • Remove the three Philips #00 screws from the bottom of the phone.
      • Two 5.5 mm screws
      • One 4 mm screw
      Ask FixBot
    2. LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: step 4, image 1 of 2 LG Thrill 4G SIM/Micro SD Card Replacement, Speaker Removal: step 4, image 2 of 2
      • Use your finger or opening tool to wedge the speaker out starting at the small notch at the bottom of the phone.
      Ask FixBot
    1. LG Thrill 4G SIM/Micro SD Card Replacement, Buttons: step 5, image 1 of 1
      • Remove the three buttons from the side and the top of the phone.
      • Power button
      • Volume button
      • 3D camera button
      Ask FixBot
    2. LG Thrill 4G SIM/Micro SD Card Replacement: step 6, image 1 of 3 LG Thrill 4G SIM/Micro SD Card Replacement: step 6, image 2 of 3 LG Thrill 4G SIM/Micro SD Card Replacement: step 6, image 3 of 3
      • Place the plastic opening tool under the bezel at either bottom corner of the HDMI cover.
      • This loosens both the HDMI and USB covers for easy removal.
      • USB Cover
      • HDMI Cover
      Ask FixBot
    3. LG Thrill 4G SIM/Micro SD Card Replacement: step 7, image 1 of 1
      • Remove the six Phillips #00 screws within the mid-cover bezel.
      Ask FixBot
    1. LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: step 8, image 1 of 3 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: step 8, image 2 of 3 LG Thrill 4G SIM/Micro SD Card Replacement, Ribbon Cable Disconnection: step 8, image 3 of 3
      • Utilize a spudger or plastic opening tool and gently disconnect the ribbon cable that is attached to the black micro-SIM card board.
      Ask FixBot
    2. LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: step 9, image 1 of 3 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: step 9, image 2 of 3 LG Thrill 4G SIM/Micro SD Card Replacement, SD/SIM Card Board Removal: step 9, image 3 of 3
      • Carefully pry the board up to detach it from its place in the phone.
      • Make sure to pry off the small tab connected to the camera unit as well.
      Ask FixBot
Khbero Baker
128 Reputation
1 Guide authored
USF Tampa, Team 1-6, Blackwell Winter 2015 Member of USF Tampa, Team 1-6, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G6
3 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 29
Past 30 Days: 105
All Time: 1,078
