Kurio's Screen Is Black
The screen is dark and it won't turn on.
Kurio Is Turned Off
Try pressing and holding the power button! The Kurio may have turned off without your knowledge.
Drained Battery
If your Kurio won't turn on, try plugging it into the charger for a while and then attempt to turn the Kurio on.
Kurio's Speakers Don't Produce Sound
It's quiet!
Kurio's Volume Is Down
Try pressing the "Volume Up" button on the side of the device.
Software Malfunction
Try rebooting your Kurio by turning it off and turning it back on!
Kurio's Speakers Are Broken
See the speaker replacement guide for further instructions.
Kurio's Screen Is Dark with White Lines
The screen has erratic patterns and the display is non-functional.
The Display Is Bad
The bad news--your display is broken. The good news--refer to the screen replacement guide for instructions!
The Kurio Is Stuck on the Boot Screen
There bouncing Kurio character is just bouncing... indefinitely.
Software Problems
This is likely a malfunction of the device's software. Try rebooting first! After that, refer to the Kurio website for possible updates or a firmware replacement.
The Kurio Is Not Charging Properly
Refer below to match your symptoms to a potential cause.
The Battery Gets Hot while Charging
First of all, try not to use your Kurio while it is charging! This places strain on the electrical components and can cause serious malfunction!
If it is still overheating while idly charging, consider replacing the battery altogether. We have a guide for that too!
The Battery Has a Short Life
Sometimes the computer sensor to the battery is no longer in sync with the actual battery level. Try running the battery down to about 5% and then fully charge it up. If this doesn't work, your Kurio's battery will naturally lose its ability to fully charge over the life of the product. Consider buying a new battery and use the battery replacement guide for further instructions.
Other Common Problems
The Kurio manufacturing website provides some answers to FAQs for simple problems, such as WiFi setup, installing firmware updates, setting parental controls and more!
Author
with
Julia
121 Reputation
0 Guides authored
Cal Poly, Team 12-36, Maness Spring 2014 Member of Cal Poly, Team 12-36, Maness Spring 2014
CPSU-MANESS-S14S12G36
4 Members
84 Guides authored
50 Comments
Is thinking and doesn't do anything.
Jaime Rodriguez - Reply Share
Please help me ....my tablet kurio7 doesn't work anymore. .. I plug it in and the screen just appear the big letters KUHIO 7 after that any button works not even turned off.
What may I do?
Have kids kurio 7 and it's not taken the charge when plugged in..
siobhanmwalsh - Reply Share
dum kurios shouled always work
gracecuffee - Reply Share
My daughters Kurio tablet wont work..it turns on but says "no Command" on the screen
leahechebiri - Reply Share
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 26
All Time: 47,227
