Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Handle is Broken
The handle of the machine is broken, cracked or will not push down properly.
Handle is Cracked
If the handle of the machine is broken or cracked, you will need to purchase a replacement online. Use this guide to help you replace the handle. A cracked handle may cause it to not push down properly.
Water is Leaking
Water leaks out of the machine instead of flowing through.
K-cup Holder is Cracked
If water is leaking at the base of the machine, the K-cup holder could be cracked. This would allow water to seep through. First check near the K-cup holder of the machine to locate any possible cracks. Once found, the K-cup holder must be replaced using this guide.
Water is Leaking from the Hose
If water is leaking near the K-cup holder, check to see if the K-cup holder is damaged. If the K-cup holder is not damaged, the hose may be clogged. You will have to open up the top of the Keurig to check for this by following this hose cleaning guide.
Water is not Dispensing
The water is not flowing through the K-cup correctly.
Water Overflows Instead of Flowing Through Machine
If the water overflows around the K-cup holder instead of dispensing, then your needles may not be penetrating the K-cup or the K-cup holder may be clogged. If the K-cup holder is not clogged, check this guide for replacing the top needle.
Water Does not Drain
If the water poured into the reservoir does not drain, it will not reach the K-cup. The drain on the Keurig may be clogged. To check if the drain is clogged and possibly unclog, use this guide to help you unclog your drain.
Machine Dispenses Slowly
The coffee is dispensing, but at a slower rate than when the machine was new.
Top Needle Does not Penetrate the K-cup
If water is dispensing abnormally slow, check to see if the top needle is dull. If it is dull, the needle will need to be sharpened. If the needle is sharp, then the needle may need to be cleaned.
Cleaning or sharpening the needle can be done by following this guide needle replacement guide.
Water Hose is Partially Clogged
If coffee is dispensing slowly, the water hose may be partially clogged. This can occur if the water in the reservoir is hard water with a high mineral content. Poor water quality can result in buildup of minerals in the dispensing tube. Unclog it using the hose cleaning repair guide.
Machine Not Brewing the Correct Amount
The machine is not producing the full amount of coffee.
K-cup has not Been Removed
If there is build up or the K-cup has not been removed, then the water will not flow through the machine as smoothly. Remove the K-cup promptly after brewing. Proceed to clean/wipe down with a soft, damp cloth. The K-cup holder can to be washed on the top shelf of the dishwasher on a low temperature cycle.
Needles are Clogged
If either the entrance or exit needles are clogged, then not all of the water will flow through. Use a straightened paper clip to enter into both the exit and entrance needles to free both from any and all coffee grounds.
Machine is Not Heating Up
The machine has stopped heating up to the temperature it is supposed to be.
Initial Water Temperature is Too Cold
If cold water is being used, the water being pumped through the brewer may not reach the temperature it is supposed to be. Warm the cup in advance by filling it with hot water and let sit for a minute or two before pouring out. Proceed to fill the cup with the desired amount of creamers before brewing coffee. Be sure to use room temperature water when filling the machine.
Water Heater is Malfunctioning
If the water heater is malfunctioning, then the water will not heat up to the proper temperature. Heating occurs when water is being pumped through the brewer, resulting in hot coffee. Take the machine apart and replace the water heater unit.
Coffee Has an Odd Taste
The coffee has a bad taste after being brewed.
Minerals are in the Water
If tap water is being used, a bad taste can occur in the coffee as a result of minerals and residue in the tap water. Boil the tap water before brewing the coffee. If there is still an odd taste, use a filter for the tap water before brewing the coffee.
Buildup has Occurred in the Machine
If there is a scaling or mineral buildup, the water will collect it when flowing through. Mix vinegar and water and let soak in the machine. Then flush the mixture with filtered or boiled water. If the taste still occurs, purchase descaling solution and clean the machine thoroughly by disassembling and cleaning each part.
Author
with
Alber Douglawi
250 Reputation
0 Guides authored
Cal Poly, Team 17-1, Forte Winter 2014 Member of Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 Members
84 Guides authored
39 Comments
It would be recommended to add links to the appropriate guides when you write "Using this guide" if possible.
Creed Borden - Reply Share
My "Mini Kurig" is not dispensing the water into the cup. I cleaned the hose and the machine is heating the water, it just will not flow from the Kurig into the cup.
Lorral Weaver - Reply Share
I threw away my first mini when we couldn’t get the cycle to complete. I bought new one. Worked ok for awhile then started same issues. I had to add water to get it to restart after shutting down. Now when this happens I add 4 oz of extra water, press button again and near end of successful cycle I just pull my cup away and let the extra weak 4 oz go into throw away cup. I also hold down the start button top with flat palm extra long. Very fussy little machine.
annesemple1969 - Reply Share
I have the newest Keurig mini and it will not take in the water from the reservoir correctly. It will only take one oz. at a time, so if I want a 10 oz cup of coffee I have to raise and lower the handle repeatedly until all the water has been taken in.
Frances Green - Reply Share
Same problem here. Water does not completely pump out of the reservoir. I too have to raise and lower the Kcup handle and press the brew button to get it to fully drain the reservoir.
Mike Canfield - Reply Share
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 51
All Time: 124,320
