Keurig Mini B-31 Top Needle Replacement
Views: 18K
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
114
All Time:
18,308
Comments: 21
20 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 15 - 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Introduction
Go to step 1 ↓
This guide will help walk you through the steps of replacing the needle of a Keurig Mini. To get into the device all you will need is a #1 Philips screw driver.
Tools
    1. Keurig Mini B-31 Top Needle Replacement, K-cup holder: step 1, image 1 of 1
      • Lift up the handle of the Keurig Mini.
      Ask FixBot
    2. Keurig Mini B-31 Top Needle Replacement: step 2, image 1 of 2 Keurig Mini B-31 Top Needle Replacement: step 2, image 2 of 2
      • Make sure to avoid the needles above and inside the K-cup because may puncture your hand
      • Firmly place a finger on each one of the three tabs that hold the K-cup holder into place, pushing in lightly. The tabs are difficult to see, but they are there and will make the removal easier. The top tab is located in the same location as the white triangle and the bottom two are located under the plastic bumps highlighted in the picture.
      Ask FixBot
    3. Keurig Mini B-31 Top Needle Replacement: step 3, image 1 of 2 Keurig Mini B-31 Top Needle Replacement: step 3, image 2 of 2
      • Firmly rock the K-cup holder from side to side, loosening the K-cup holder from its seat.
      Ask FixBot
    4. Keurig Mini B-31 Top Needle Replacement: step 4, image 1 of 1
      • Pull the K-cup holder straight out.
      Ask FixBot
    1. Keurig Mini B-31 Top Needle Replacement, Top: step 5, image 1 of 3 Keurig Mini B-31 Top Needle Replacement, Top: step 5, image 2 of 3 Keurig Mini B-31 Top Needle Replacement, Top: step 5, image 3 of 3
      • Open the top lid of the Keurig.
      • Pull directly outwards on one of the arms that holds the top lid in place. It will take some force to get the arm off the peg. Once one side is off, repeat the process on the second arm.
      Ask FixBot
    2. Keurig Mini B-31 Top Needle Replacement: step 6, image 1 of 1
      • Lay the Keurig on its back with the water reservoir pointing away from you.
      Ask FixBot
    3. Keurig Mini B-31 Top Needle Replacement: step 7, image 1 of 1
      • Avoid the top needle as it may puncture your hand.
      • Unscrew the two 9mm #1 Philips screws that hold the top plastic cover in place.
      Ask FixBot
    4. Keurig Mini B-31 Top Needle Replacement: step 8, image 1 of 1
      • Set the Keurig in an upright position with the front side facing you.
      • Pull the cover off the top of the Keurig. It should come off easily with little force.
      Ask FixBot
    5. Keurig Mini B-31 Top Needle Replacement: step 9, image 1 of 1
      • Firmly grasp the hose and pull it off of the plastic nozzle.
      Ask FixBot
    1. Keurig Mini B-31 Top Needle Replacement, Top Needle: step 10, image 1 of 1
      • Unscrew the two 9 mm #1 Philips screws at the top of the device.
      Ask FixBot
    2. Keurig Mini B-31 Top Needle Replacement: step 11, image 1 of 1
      • Push down lightly on the nozzle that the hose was attached to. The plastic housing along with the needle should pop off without much force.
      Ask FixBot
Andrew Adriance
1,914 Reputation
7 Guides authored
Cal Poly, Team 17-1, Forte Winter 2014 Member of Cal Poly, Team 17-1, Forte Winter 2014
CPSU-FORTE-W14S17G1
5 Members
84 Guides authored
1 Guide Comment
This is great but where do I buy the top needle replacement part?
Jen - Reply Share
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 114
All Time: 18,308
