Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Speaker Will Not Charge/Power On
The speaker will not respond or show any sign of powering up.
Faulty Charging Cable
If your micro USB cable shows any kind of wear, try using another micro USB cable that works. Some of the internal wires may have frayed.
Damaged Charging Port
If the micro USB charging port is deformed or loose, it may not be able to connect with the charging cable well enough to charge effectively. Please refer to our USB Port Replacement Guide to find out how to replace a damaged charging port.
Faulty Battery
If the speaker works when it is plugged in, but does not work when it is not plugged in, the speaker may have a faulty battery. To replace the battery, please refer to the Battery Replacement Guide.
Faulty Circuit Board
This is a hard issue to diagnose. If previous solutions did not work, the issue may be a faulty circuit board. Accessing the main circuit board, however, requires destruction of parts of the speaker.
Buttons are Unresponsive
The buttons on the speaker either do not light up or are unresponsive.
Incorrect mode enabled
The speaker may be in a different (programming?) mode entered by mistake. Even power cycling the speaker by removing the battery doesn’t exit this mode.
Symptoms:
  • It will only turn on by attaching power, and it immediately turns off when removing power, making the power on and off sounds
  • None of the buttons do anything if not showing the current power level
  • Charging works
  • Audio via jack port works, when powered
How to fix it:
  • Attach power and disconnect immediately: the speaker should stay on
  • Press “JBL connect” and “Volume Up” together for ~5 seconds
The speaker should reset and then work normally.
Faulty Circuit Board Under Power Button
Because the JBL Flip 4 is sealed very well, it is unlikely any debris would be blocking the buttons. The main cause for unresponsive buttons would be a faulty control board. To access the control board under the buttons, please refer to the Controls Board Replacement Guide. Unlatch the wire that is connected to the circuit board, and then plug it back. If the lights on the board do not flash, replace the circuit board. If the lights on the board flash, the speaker should be working again.
Speaker has Lost Significant Battery Life
Your speaker does not hold a charge or turns off immediately after unplugging it.
Faulty Battery
If the battery does charge but loses the charge very quickly, this may be because the usable capacity of any battery decreases as the number of its discharge/charge cycles increases. Thus, new batteries hold much more power than older ones. You can find instructions to replace the battery by referring to the Battery Replacement Guide.
The Speaker Won’t Connect Through Bluetooth
Your speaker will not connect to a device using bluetooth while powered on.
Connected to Another Device
If another phone, TV, or computer that has connected to your speaker in the past is within bluetooth range, it may have already connected to your speaker, thus not letting your preferred device to connect. The JBL Flip 4 can only connect to one device at a time. To fix this, try to find this intercepting device and disconnect the speaker from that device.
If you cannot find the intercepting device, try to isolate the speaker and your preferred device. For example, you can try going in a closed room far away, to physically disconnect the speaker from the intercepting device. Turn off the speaker and turn it back on and allow your preferred device to be the first device the speaker finds to connect with.
Interference from Nearby Devices
There is a chance that a device near your speaker is sending signals with the same frequency that your speaker uses to connect via bluetooth. These devices usually include wifi routers, baby monitors, or another wireless speaker. To fix this problem, move any barriers around the speaker that could be interfering, or restart a device that could be causing the interference.
No Bluetooth Audio Driver
Sometimes bluetooth devices have trouble connecting to computers because the computer does not have the software required to use bluetooth. Most computers should have the standard bluetooth audio driver that the JBL Flip 4 uses, but if your computer seems like it does not, you may need to refer to your computer’s manufacturer to download the audio drivers required.
The Speaker Makes Crackling Noise
While playing audio through the speaker, your speaker starts making unusual crackling or static noises.
Device Not in Range
The connected device could be too far away from your speaker. The effective bluetooth range is around 30 feet. Any walls or similar obstacles may reduce this range. To fix this, place the connected device closer to the speaker.
Damaged Driver (Speaker)
If the abnormal sounds do not sound electronic or if they happen at certain audio pitches and/or volumes, the speaker’s driver themselves could be damaged. To replace the individual speakers, you can refer to the Front Active Speaker Replacement Guide.
Inconsistent Electrical Connections
If the previous solution did not work, poor electrical connections inside the speaker may be causing the issue. Unfortunately, these poor electrical connections, ranging from failing solder joints to loose plugs, can be incredibly hard to find. Additionally, accessing the main circuit board requires the destruction of parts of the speaker which will significantly decrease or impair the performance of the device.
Author
with
Philip Pang
1,503 Reputation
4 Guides authored
Cal Poly, Team S4-G3, White Fall 2018 Member of Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Members
60 Guides authored
106 Comments
My jbl flip 4 is not taking up charge it only works while plugged in. What can I do to fix this problem
Tito - Reply Share
Mine did the same thing, you need a new battery, go to amazon, it’s about $17, very easy fix.
Dan M - Reply Share
it keeps cutting off after about an hour. i’ve reset it several times, but it continues to do the same thing. any suggestions?
Lyn Steyne - Reply Share
My jbl flip4 ‘s sound is crackling while playing and then will shutdown… BatteryBattery life has become short…
But it plays normally while charging
Please help!
Jayakrishnan - Reply Share
I have the exact same problem as Jayakrishnan
Please help!
Daniel - Reply Share
Past 24 Hours: 11
Past 7 Days: 49
Past 30 Days: 250
All Time: 193,315
