JBL Flip 4 Battery Replacement
    1. JBL Flip 4 Battery Replacement, Shell: step 1, image 1 of 3 JBL Flip 4 Battery Replacement, Shell: step 1, image 2 of 3 JBL Flip 4 Battery Replacement, Shell: step 1, image 3 of 3
      • Insert the plastic opening tool in the crack in between the cover and the rubber spine with the power button.
      • Pry off the cover, beginning with the side without the volume and bluetooth buttons.
      • When prying the cover off, the six clips (three along each side of rubber spine) that attach the cover to the speaker will make snapping sounds.
      • Watch out not to damage the clips on the buttons' side, pry open with caution.
      • Pull the cover off with your thumbs.
      Ask FixBot
    2. JBL Flip 4 Battery Replacement: step 2, image 1 of 3 JBL Flip 4 Battery Replacement: step 2, image 2 of 3 JBL Flip 4 Battery Replacement: step 2, image 3 of 3
      • Remove four 13 mm JIS #0 screws attaching the rubber spine to the speaker, located on both sides of the inside of the speaker.
      • Use the plastic opening tool to release the clips holding the central part of the rubber spine.
      • Pry away one end of the rubber spine with your thumbs and it should come off.
      • Prying off the spine may take some persuading.
      • The speakers are strong magnets. Keep it away from other sensitive electronics.
      Ask FixBot
    1. JBL Flip 4 Battery Replacement, remove cap: step 3, image 1 of 3 JBL Flip 4 Battery Replacement, remove cap: step 3, image 2 of 3 JBL Flip 4 Battery Replacement, remove cap: step 3, image 3 of 3
      • The end cap opposite to the USB port: Twist - or - remove screws from the cap. (depends on your model-version: only older version have 9mm Phillips #1 screws)
      • Pull the end cap off with your hands.
      Ask FixBot
    2. JBL Flip 4 Battery Replacement: step 4, image 1 of 3 JBL Flip 4 Battery Replacement: step 4, image 2 of 3 JBL Flip 4 Battery Replacement: step 4, image 3 of 3
      • Remove two 11mm Phillips #1 screws on the battery cover.
      • Pull the battery cover off with your hands.
      Ask FixBot
    3. JBL Flip 4 Battery Replacement: step 5, image 1 of 3 JBL Flip 4 Battery Replacement: step 5, image 2 of 3 JBL Flip 4 Battery Replacement: step 5, image 3 of 3
      • Remove the large white plug that connects the wires from the battery to the main board using your hands.
      • Pull the battery out with your hands.
      • If the battery is swollen, you might not be able to pull it out with your hands, you might just rip the cables+charging board out.
      • In this case: You can pushing out the Battery, which we documented in an extra guide.
      • A short preview: You can remove the other radiator, unscrew the charging port and gently pull it out just a bit so a pencil (flat end) can fit in and push out the battery from this side.
      • The port might be hot glued and under the tapes there are very small normal and ribbon cables, so be careful not to cut or rip them.
      • More details and pictures in the separated extra guide.
      Ask FixBot
201 other people completed this guide.
Philip Pang
1,470 Reputation
4 Guides authored
Cal Poly, Team S4-G3, White Fall 2018 Member of Cal Poly, Team S4-G3, White Fall 2018
CPSU-WHITE-F18S4G3
4 Members
60 Guides authored
80 Guide Comments
Is the battery glued into the socket like the Flip 3?
Kenneth - Reply Share
No it isn’t. but the black rubber around it makes it really hard to get out. try to push it from the otherside by removing the charging-port.
Be careful not to pierce the battery
Richardo Otros - Reply Share
Yes with me the battery was glued
Diter Freeman - Reply Share
Be careful and don’t do like me: my old battery was bloated, so I had to push from the other side, but when doing so, I ripped the ribbon cable from the power button… now trying to find a replacement cable
jmbarroso - Reply Share
Did you find the cable of the power button?
mohamed da - Reply Share
Past 24 Hours: 88
Past 7 Days: 508
Past 30 Days: 2,249
All Time: 296,441
