Note: This troubleshooting page covers only the Iomega Z100S2 Zip Drive.
Zip Drive not recognized by computer
The zip drive in not recognized by the computer when plugged in.
Bad port
The zip drive may be plugged into a faulty port. Try plugging the device into another port.
Faulty cord
The cord might be damaged in some way. Try replacing the connection cord and make sure the zip drive is on before plugging it back into the computer.
Not compatible with current operating system
Your operating system is not compatible with the zip drive.
Older operating system
Since the device is relatively old, it may not be compatible with your computer's current operating system. Try using the zip drive on a computer with an older operating system such as: Microsoft Windows 95 or 98, Linux, Mac OS 6.x 7.1-7.5 and Mac OS 7.6 to 9.2.
Zip drive not being read correctly
Your device is not reading zip drives.
Faulty logic board
This could be due to a faulty logic board. You can use our free repair guide to remove the logic board and check for any obvious damage.
Zip drive doesn't save files
The device will not save files to a zip drive.
Faulty logic board
Most likely due to a faulty logic board. Your best bet is to remove and the logic board and check for any damages.
Device will not turn on
Try switching the power off and on again. If that doesn't work, try changing power sources (outlets). If none of that works your only option will be to replace the power cord.
"Click of Death"
If you hear the "Click of Death" your device has mostly likely failed and you will need to replace it. If you heard "the click" and your device is still working do not continue to use it, all the data on your drive will be lost!
Zip drive will not work
If you have exhausted all other options, your best course of action is to buy a new zip drive.
Robin Verweij
1 Reputation
0 Guides authored
Cal Poly, Team 7-53, Amido Fall 2010 Member of Cal Poly, Team 7-53, Amido Fall 2010
CPSU-AMIDO-F10S7G53
4 Members
36 Guides authored
1 Comment
I presume the 'S' and 'P' in Z100S2 and Z100P2 donote series and parallel?
I don't know if Z100S2 drives work on old PCs with SCSI, but I have found out the hard way that Z100P2 drives do not work on old hardware audio equipment!
I opened my Z100S2 to try and figure the failed eject button problem and upon reassembly I now have to disconnect and reconnect the power to stop the amber light flashing after loading and ejecting the disk.
xavierbusquet - Reply Share
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 38
All Time: 4,523
