Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Bike Won’t Collapse
The seat will not fold down and the front wheel is stuck in the drive position.
Too Much Weight On the Device
Do not attempt to unlock the Fold Lock while sitting or leaning on the seat. Doing so applies to much pressure to be able to release the locking mechanism. Stand besides the bike and pull up on the Fold Lock to collapse the bike.
Fold Lock Jammed
Push down on the Fold Lock and then attempt to pull up in order to release the lock. If the Fold Lock has dirt or sand in the mechanism, folding will become quite difficult. Compressed air directed under the Fold Lock Handle can help to clean out the debris.
Fold Lock Jammed (Water Damage)
If the bike was recently exposed to water, allow the device to fully dry before attempting to collapse it. Compressed air or a blow dryer can help to speed up the process for drying the bike.
The Brakes Don’t Stop the Bike
When you pull the brakes, the bike continues to move forward without slowing down.
Brakes Are Not Pulled with Enough Force
Pull the brakes until the handle stops moving or the bike begins to slow down.
Brakes Are Not Tight Enough
If the brake bar can be pulled to the handle, the brakes may be too loose. Check the brakes while pulling them, to see if enough force is applied. Tighten the steel cable of the brakes by loosening the grip nut with an Allen wrench and pulling more of the steel cable past the grip. For more help, check this device page guide.
Brake Pads Are Misaligned
The brake pads are carefully calibrated to a certain height to ensure that pressure pushes on the wheel. If the brake handle can be pulled to the handlebar, the brake is too loose. Check that the brake pads are only 1-2 mm away from the wheel. Adjust your brake controller to maintain this distance.
Brake Cable Has Been Severed
Remove the brake frame and follow the cable. If the cable is cut, the brakes need to be replaced. Follow our replacement guide.
Brake Discs Worn Down
After repeated use, the brake pads can wear down and become ineffective. These can be replaced. See our replacement guide.
Bike Won’t Start
When you turn the ignition, the bike does not light up or turn on.
Bike Is Not Turned On
If the LED display is not on, that means that the bike is not on. Turn on the bike by inserting the key into the ignition and turning it clockwise.
Ignition Slipped Into the Frame
Pushing too hard on the ignition can cause it to slip into the frame. You will have to repair it yourself following this guide.
Battery Is Dead
Full charge gives you about 10 miles; battery can be recharged using the charger that comes with the bike. If the battery is left uncharged for over six months, it becomes defective and it won’t recharge. In this case, it needs to be replaced using this guide.
The Back Lights Won’t Turn On
The front light is unresponsive or does not turn on when the bike is running.
Light Bulb Is Dead
The light bulb can be replaced. Follow our replacement guide.
Wiring Is Faulty
Open the back of the front frame by removing the screws. Follow the wiring from the battery to the front light bulb. Make sure that the wires are properly connected and intact.
The Battery Dies Too Quickly
You’ve charged the bike for the recommended time, but the battery is dying too quickly.
If the bike has been kept in a cold environment, it could reduce the quality of the product and cause the battery to die quickly. Make sure to keep the bike out of the cold and the rain to ensure optimal quality.
Charger Is Faulty
Move the charger to a separate plug and recharge. If the battery continues to die, the charger is faulty and needs to be replaced. This can be ordered online.
Battery Is Corroded
Leaving the bike in the heat can result in the battery to rupture and leak, thus corroding the battery. The best thing to do in this case it to replace the battery, which you can do by following this guide.
Battery Is Old
Batteries have a recommended amount of charge cycles before the battery begins to deteriorate. If the battery is quite old, or undergone a number of recharges, consider replacing the battery. You can find a guide to do so at this guide.
Author
with
Christian Roberts
263 Reputation
1 Guide authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
72 Guides authored
10 Comments
My back tire keeps going flat.
TONYA SMITH - Reply Share
Do you guys sell replacement seats like the post and Going to the hinge I just hit a bump on it really fast and didn’t have breaks going down hill on accident and after hitting the bump the seat busted off the hinge and is now where I am unable to ride it. Do you know of where I can get a replacement part or to have this kind of thing repaired?
Craig Borth - Reply Share
the back tire keeps going flat,how can I get a back tire
pops6949 - Reply Share
i still having problem with the back tire,continue loosing air ,can u tell me what that i need to repair it
Can some post there wiring inside there xls folding scooter I need to see the throttle wiring
nick.zion26 - Reply Share
Past 24 Hours: 4
Past 7 Days: 8
Past 30 Days: 56
All Time: 2,950
