Up to 20% off select tools
Hover-1 XLS Battery Replacement
Views: 15K
View statistics:
Past 24 Hours:
5
Past 7 Days:
35
Past 30 Days:
169
All Time:
15,159
Comments: 22
5 comments on steps, 17 guide comments.
Go to guide comments
Completed: 3
3 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
If the bike is not performing at its maximum capability, its battery may be corroded, and you should replace it as soon as possible. Before beginning this guide, you will need power tools or a chemical remover to deal with Teflon tape on the screws.
    1. Hover-1 XLS Battery Replacement, Battery: step 1, image 1 of 3 Hover-1 XLS Battery Replacement, Battery: step 1, image 2 of 3 Hover-1 XLS Battery Replacement, Battery: step 1, image 3 of 3
      • Remove the four, 12mm Hex #3 screws located on the bottom half of the battery compartment.
      • There are four screws that need to remove. Two on one side and the two on the opposite side.
      Ask FixBot
    2. Hover-1 XLS Battery Replacement: step 2, image 1 of 3 Hover-1 XLS Battery Replacement: step 2, image 2 of 3 Hover-1 XLS Battery Replacement: step 2, image 3 of 3
      • Remove the adhesive holding the wires tightly.
      • You can use a sharp object to score the adhesive before pulling.
      • Pull on both sides of the wire connections.
      Ask FixBot
3 other people completed this guide.
Author
with
Jonathan Hidalgo
686 Reputation
5 Guides authored
Cal Poly, Team S1-G2, White Winter 2019 Member of Cal Poly, Team S1-G2, White Winter 2019
CPSU-WHITE-W19S1G2
3 Members
72 Guides authored
17 Guide Comments
That looks easy enough to do. My problem is finding a replacement battery. Do you have any idea where they are available?
David Schultze - Reply Share
David did you happen to find one? Please let me know I've been looking for one
Michael Hawk - Reply Share
If anyone find a 1:1 replacement battery for this, or at the very least a wiring diagram, please post it as it's near impossible to find anything on this thing in 2022.
GutZ Era - Reply Share
So the yellow and a red are for the ignition and the other red and black ig is a standard ground and positive with the white being I think the temperature sensore wire. Hope this helps also trying to find a replacement and may try wiring one up.
Batman and King - Reply Share
Hi, where can you find the battery replacement? I have my scooter and the battery needs to be replaced.
Mary - Reply Share
Past 24 Hours: 5
Past 7 Days: 35
Past 30 Days: 169
All Time: 15,159
