Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Incorrect Plate Temperature
The plates of the flat iron will not change temperature when the dial selector is at different positions.
Faulty Dial Selector
Attempt changing the heat dial to test if the plates will heat up. If the issue persists, test the dial with a multimeter at various temperature settings. If the voltage across the dial is always the same, replace the dial with this guide.
The Plates Heat Up, But Light Is Not On
After turning the flat iron on, the plates will get hot, but the LED light is not illuminated.
Faulty LED Light
Test the power on the flat iron by switching the power switch from the off position to the on position. If the LED power indicator doesn’t light up, but the plates get hot, then the LED may be faulty.
The Plates Will Not Get Hot
The light is on, but the plates will not heat up.
Faulty Thermal Fuse
Inspect the internal thermal fuse visually. If you cannot visually tell if the thermal fuse is intact or blown, you can test the fuse with a multimeter. If you find the fuse to be faulty, replace it with this guide.
The Iron Will Not Turn On When Plugged In
You are having trouble getting the flat iron to power on
Broken Switch
Test the power on the flat iron by switching the power switch from the off to on position. If the switch is in the on position and the flat iron plates aren’t heating up, the switch may be faulty. If they do heat up, then the LED may be faulty.
Broken Cord
Check the cord for frayed or exposed wires. If wires are visible, then replace the cord with this guide.
Author
with
Ben Miller
288 Reputation
1 Guide authored
IUPUI, Team 3-4, Baechle Fall 2016 Member of IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 Members
60 Guides authored
16 Comments
Have a brand new Hot Shot Tools flat iron. Only used a couple weeks. When plugged in, it gives an error message. Any advice.
Mason Johnson - Reply Share
Having the same problem - Just got it for Christmas only use about once weekly and now when I plug it in I just get error code- frustrating
Amy A - Reply Share
My brand new purple Remington straightener won't get hot . It turns on but won't get hot. The bottom handle part does but not the part that straightens your hair. HELP PLEASE
Tiffany - Reply Share
Hi, in my hoot tools flat iron i have the word err on the dysplay and dont heat. Help me please…
Alberto Salas - Reply Share
My flat iron will not turn on when plugged in and I can’t figure out why?.
Tessa Ely - Reply Share
Past 24 Hours: 3
Past 7 Days: 15
Past 30 Days: 65
All Time: 47,042
