Up to 20% off select tools
Hot Tools HPK12 Control Assembly Replacement
Views: 3.6K
View statistics:
Past 24 Hours:
4
Past 7 Days:
20
Past 30 Days:
117
All Time:
3,565
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Missing Steps
Oops! This guide is currently missing one or more important steps.
Tools
Introduction
Go to step 1 ↓
This guide will show you how to replace the control assembly on your Hot Tools HPK12 flat iron. Make sure your flat iron is unplugged and completely cooled down before beginning.
    1. Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: step 1, image 1 of 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: step 1, image 2 of 3 Hot Tools HPK12 Control Assembly Replacement, Prerequisite Only: step 1, image 3 of 3
      • Remove round plastic cover near cord base by prying under the side with the metal spudger.
      • Flip the device and remove the other round plastic cover near the base of the cord.
      • Use the Phillips #1 screwdriver to remove the 5.5mm PH1 screw and washer under the plastic cover and set both aside.
      Ask FixBot
    2. Hot Tools HPK12 Control Assembly Replacement: step 2, image 1 of 1
      • Use the metal spudger to push the center pin through to the other side.
      Ask FixBot
    3. Hot Tools HPK12 Control Assembly Replacement: step 3, image 1 of 2 Hot Tools HPK12 Control Assembly Replacement: step 3, image 2 of 2
      • Lift back plastic cover to expose spring assembly.
      • Be careful not to damage the power cord by bending or twisting it too much while performing this step.
      • Grip the exposed end of the spring assembly and remove it.
      • The side with the two ends of the spring goes into the recessed area of the iron
      Ask FixBot
    4. Hot Tools HPK12 Control Assembly Replacement: step 4, image 1 of 1
      • Use the JIS #0 screwdriver to remove the two 3.5mm “J0” screws that attach the control assembly cover to the flat iron base.
      Ask FixBot
    5. Hot Tools HPK12 Control Assembly Replacement: step 5, image 1 of 3 Hot Tools HPK12 Control Assembly Replacement: step 5, image 2 of 3 Hot Tools HPK12 Control Assembly Replacement: step 5, image 3 of 3
      • Lift upward on the control assembly cover to remove it from the flat iron base.
      • Remove dial and switch cover and set aside.
      Ask FixBot
    6. Hot Tools HPK12 Control Assembly Replacement: step 6, image 1 of 3 Hot Tools HPK12 Control Assembly Replacement: step 6, image 2 of 3 Hot Tools HPK12 Control Assembly Replacement: step 6, image 3 of 3
      • Use your JIS #0 screw driver to remove the two 6mm “J0” screws that are attached to the flat iron base and set them aside.
      • Lift the backing plate upwards to remove it from the flat iron.
      • Use the Phillips #0 screwdriver to remove two 4mm “PH0” screws that attach the circuit assembly to the flat iron base.
      Ask FixBot
Author
with
Aaron Whitlock
249 Reputation
2 Guides authored
IUPUI, Team 3-4, Baechle Fall 2016 Member of IUPUI, Team 3-4, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G4
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 20
Past 30 Days: 117
All Time: 3,565
