Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Distorted audio or no audio
Audio sounds fuzzy/distorted, or doesn't play at all.
Loose Speaker Membrane
Furby's speaker membrane can loosen over time, lowering the quality of audio or even disabling audio all together. If there is still some audio, the membrane is likely loose and needs pressure applied to it.
Broken Speaker
Furby's speaker may also be broken entirely, in which case all audio will be gone and replacing the speaker will be necessary.
Furby’s “feet” immobile
Furby won't move correctly or at all.
Feet are dirty
Furby's feet may accumulate grime over time, which prevents proper movement. If this occurs it is necessary to clean your Furby. Simply open up the base of the furby as if you were changing the batteries. Once the battery hatch is removed, you just need to clean the hatch where the feet are and Furby should move normally again.
Device not powering on
Furby is unresponsive when batteries are in.
Reset Button
Before removing any components, try the reset button located near the battery carriage. Remove the base of the Furby and near the batteries will be a small button with a sticker next to it stating "Refresh ->".
Battery Acid
If pressing the reset button didn't return power to the device, then check to make sure battery acid hasn't destroyed the battery coils.
Author
with
Jordan Castillo
1,078 Reputation
5 Guides authored
Cal Poly, Team 15-5, Livingston Fall 2016 Member of Cal Poly, Team 15-5, Livingston Fall 2016
CPSU-LIVINGSTON-F16S15G5
4 Members
72 Guides authored
2 Comments
I have a 2012 yellow Furby that works ok when it’s on but it’s doesn’t want to stay awake. Also it changed personalities and I have tried to reset it and it won’t change back. I don’t know how to fix this. Anybody have a clue?
ccupcat - Reply Share
Try and do factory reset by flipping the furby upside down, pull its tail and press on tongue all at the same time.
Anne Khairi - Reply Share
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 116
All Time: 3,719
