Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Mytouch 4G Won't Charge
You can not get your phone to begin charging.
Faulty Outlet
Try a different outlet around your house to see if the phone will charge and that the outlet is not faulty.
Battery and Charger Connection Loose
Check to see if the battery is loose by taking the battery out and putting it back in by following the HTC MyTouch 4G Battery Replacement Guide. Unplug the charger and plug it back in as well to make sure connection is made.
Broken Charger
Inspect the charger and make sure that there is no damage that has been caused to the charger. If there is no damage, try cleaning debris from the charger and plugging it back in to see if it will work.
MyTouch 4G Won't Turn On
Your phone is no longer turning on.
Holding Power Button
If there are no other reasons for the phone not turning on, simply press and hold on to the power button. After holding for 10 seconds or longer, the phone might turn on.
Battery is drained
Check to see if it is possible to charge your battery. Wait over two minutes before trying to turn your phone on again to see if the battery was just completely drained. If it does hold a charge, charge it fully and turn it back on.
Faulty Outlet
If you were not able to get the phone to start a charge after two minutes, the outlet may not be working. Try a different outlet around your house to see if the phone will charge.
Faulty Battery
If the battery does not hold a charge, it could be faulty. Follow the HTC MyTouch 4G Battery Replacement Guide to replace the battery if this is the case.
Bad Motherboard
The problem could be the motherboard of the phone has gone bad if none of the other solutions has worked. Follow the HTC MyTouch 4G Motherboard Replacement Guide.
MyTouch 4G Audio Not Working or Unclear
The sound of your phone has stopped working or is static.
Settings on mute
Go into the settings of your phone and make sure that the volume is turned on and not set to mute.
Restart Phone
Try restarting your phone to see if that will fix the sound not working.
Recently Downloaded Applications
Have you recently downloaded any apps that could be interfering with the sound on your phone? If you have, try deleting the application to fix the problem.
Faulty Speakers
If none of those fixes work to correct the sound; then the speakers may be faulty. Follow the HTC MyTouch 4G Speaker Replacement Guide to fix the speakers.
MyTouch 4G Screen Not Working
The phone turns on and makes the initial booting sounds, however your screen is still black.
Faulty LCD
If this is the case, you have a faulty LCD in your phone. Follow the HTC MyTouch 4G LCD Replacement Guide to fix this issue.
MyTouch 4G Keypad Not Working
The buttons of your keypad are not responding.
Restart Phone
After checking the settings, try restarting your phone to see if that will fix the keypad not working.
Faulty Keypad
If the keypad is still not working after restarting the phone, the keypad is faulty. Follow the HTC MyTouch 4G Button Replacement Guide to fix it.
Author
with
Braden
425 Reputation
2 Guides authored
USF Tampa, Team 16-5, Watkins Spring 2014 Member of USF Tampa, Team 16-5, Watkins Spring 2014
USFT-WATKINS-S14S16G5
2 Members
60 Guides authored
1 Comment
My 'My Touch 4G Slide' does not come on. Except for a faint red
J Taylor - Reply Share
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 10
All Time: 4,359
