HTC MyTouch 4G Motherboard Replacement
    1. HTC MyTouch 4G Motherboard Replacement, Flip Phone Over: step 1, image 1 of 1
      • Flip your phone over and hold the phone with the back facing you.
      Ask FixBot
    2. HTC MyTouch 4G Motherboard Replacement, Remove the back case.: step 2, image 1 of 1
      • Place the prying tool into the notch at the bottom of the case and pull up to remove.
      Ask FixBot
    3. HTC MyTouch 4G Motherboard Replacement, Remove the battery: step 3, image 1 of 2 HTC MyTouch 4G Motherboard Replacement, Remove the battery: step 3, image 2 of 2
      • Use the plastic prying tool in the upper left-hand corner notch of the battery to remove.
      Ask FixBot
    1. HTC MyTouch 4G Motherboard Replacement, Removing Screws: step 4, image 1 of 1
      • Remove the two T5x5mm Screws with the T5 Torx Screw driver.
      • Remove the one Phillips screw with the Phillips #00 Screwdriver.
      Ask FixBot
    2. HTC MyTouch 4G Motherboard Replacement, Removing back case.: step 5, image 1 of 3 HTC MyTouch 4G Motherboard Replacement, Removing back case.: step 5, image 2 of 3 HTC MyTouch 4G Motherboard Replacement, Removing back case.: step 5, image 3 of 3
      • Use the plastic opening tools to remove the back case.
      • There are four T5x5mm screws. Use the T5 Torx Screwdriver to remove them.
      • Using the plastic opening tools, remove the Wifi antenna.
      Ask FixBot
    3. HTC MyTouch 4G Motherboard Replacement, Removing four T5 Screws: step 6, image 1 of 2 HTC MyTouch 4G Motherboard Replacement, Removing four T5 Screws: step 6, image 2 of 2
      • There are three button ribbons on the phone that need to be pulled down off of the case.
      • With the plastic opening tools, pull the button ribbons down away from the frame without completely removing them.
      Ask FixBot
    4. HTC MyTouch 4G Motherboard Replacement: step 7, image 1 of 3 HTC MyTouch 4G Motherboard Replacement: step 7, image 2 of 3 HTC MyTouch 4G Motherboard Replacement: step 7, image 3 of 3
      • After making sure the button ribbons are away from the frame, insert the plastic opening tool into the frame and remove it.
      • Remove two Philips screws holding the Motherboard in place.
      Ask FixBot
    5. HTC MyTouch 4G Motherboard Replacement: step 8, image 1 of 2 HTC MyTouch 4G Motherboard Replacement: step 8, image 2 of 2
      • Three ribbon cables and the vibration motor need to be disconnected from the motherboard.
      • Using the plastic opening tools, pull up on the power button ribbon to gently detach it.
      • Remove the vibration motor by gently pulling it off of the motherboard.
      Ask FixBot
    6. HTC MyTouch 4G Motherboard Replacement: step 9, image 1 of 3 HTC MyTouch 4G Motherboard Replacement: step 9, image 2 of 3 HTC MyTouch 4G Motherboard Replacement: step 9, image 3 of 3
      • Remove the digitizer ribbon cable with the plastic opening tools.
      • Remove the LCD ribon cable from its connector.
      • It is now safe to release the Motherboard from the clips holding it in place. Start at the top clip of the phone and move your way around gently releasing each clip.
      Ask FixBot
    7. HTC MyTouch 4G Motherboard Replacement: step 10, image 1 of 3 HTC MyTouch 4G Motherboard Replacement: step 10, image 2 of 3 HTC MyTouch 4G Motherboard Replacement: step 10, image 3 of 3
      • Do not lift the Motherboard off the phone. The LCD Ribbon is still connected to it.
      • Lift the Motherboard towards the left to expose the LCD clamp connector.
      • Open the clamp connector of the LCD ribbon by carefully pulling it up with the plastic opening tools.
      Ask FixBot
    8. HTC MyTouch 4G Motherboard Replacement: step 11, image 1 of 1
      • The motherboard is now removed.
      Ask FixBot
2 other people completed this guide.
Braden
425 Reputation
2 Guides authored
USF Tampa, Team 16-5, Watkins Spring 2014 Member of USF Tampa, Team 16-5, Watkins Spring 2014
USFT-WATKINS-S14S16G5
2 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 18
Past 30 Days: 96
All Time: 1,230
