Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
The Tablet Will Not Power On
I can’t get the device to power on
Out of Battery Power
Make sure that the tablet still has battery power by plugging it into its charger for at least an hour. If your tablet still wont turn on, unplug your tablet from the charger, remove the battery for 10 seconds and then place it again. A guide that will help you in replacing the battery can be found here.
Malfunctioning Battery
If the tablet doesn't work after charging, the battery has likely gone bad. View the battery replacement guide here. Alternatively, the tablet’s contacts may not be connecting to the battery.
The Tablet Will Not Recharge
"I can't recharge my device, even with a new battery in it!"
Faulty wall socket
Ensure that the wall socket you are using is functioning and maintains contact with the charger; some tablet power adapters will say they are being charged even if they are not receiving power through the wall socket.
Damaged Power Socket on the Tablet
If your tablet has been dropped or suffered other physical trauma, the power socket may be nonfunctional due to deformation, lose wires, or cracked circuits. View the replacement guide for the power connector here.
The Display is Malfunctioning
The screen isn't displaying properly
The Display is Blank!
Ensure the tablet is on. If the screen is black but the tablet is on, it could be faulty connections to the motherboard or a malfunctioning motherboard. View the motherboard replacement guide here.
Cracks on The Display
Small cracks can be repaired or at least mitigated by application of glass repair compounds and gentle rubbing, though care should be taken not put too much pressure on the screen. Unfortunately, there is very little to be done to repair large cracks. Large cracks require the display to be replaced.
The Tablet is Not Responding
No matter what I do, I can’t interact with the tablet
The Display is Active But Not Responding to Touch
If you can see your clock running but the tablet is not responding to your inputs, make sure you are using the touchscreen correctly.
Use the tip of your finger - not your fingernail - and if you are using a stylus, ensure that is compatible with capacitive touchscreens.
If the tablet doesn't respond to correct inputs, your display may be malfunctioning and require replacement.
The Screen is Frozen and Not Responding
If the clock is frozen and the display is still on, your tablet has likely crashed. Hold down the power button for several seconds to force a shutdown, then turn it back on.
If the power button does not turn the device off, remove the battery for thirty seconds before re-inserting the battery.
The Cameras are Taking Bad Pictures
The photos the cameras are taking are abnormally blurry or out of focus
The Pictures are Blurry
Make sure that you are holding the tablet steady when you take a picture. Try placing the tablet on a solid surface and taking a picture to keep it steady.
Ensure that the camera lens is clean of finger marks and other marks. Wipe both lenses off with a small monitor cleaning cloth.
The Pictures are Heavily Distorted or Blank
If your pictures have strange colors and dead pixels, your camera may be malfunctioning and will require replacement.
If the front camera is malfunctioning, you will have to replace the display assembly.
The Speaker Sounds are Quiet or Distorted
If your sound is on but you cannot hear anything, your speakers may be broken.
The Speaker’s Connection to The Motherboard is Loose
If the tablet has been dropped, the speaker’s connections may have been jarred loose. Luckily, replacement is a simple re-attachment, which is shown here.
The Speaker is Broken
If the speaker’s connections are still attached but the speaker is not working, it will require replacement, shown here.
Headphones are not Working
"If your headphones are silent or produce distorted noise, your headphone jack may be broken."
The Headphones are Broken
Ensure that the headphones are working by plugging them into a different device, such as a laptop. Also, try turning the headphone's jack within the tablet's headphone port; old headphones may only be able to make contact with the connector at certain angles.
The Headphone Jack is Damaged
If you have dropped the tablet, the headphone port may have been dented, preventing it from making contact with the headphones's connector. Extreme deformation will require replacement of the headphone jack circuit board, which is explained here
The Tablet Cannot Connect to The Internet
I cannot connect to any wireless signals
Wireless Settings are Incorrect
You may have inadvertently disabled your wireless receiver or enabled airplane mode. Open your tablet’s settings and ensure that WiFi and Wireless is enabled, and that Airplane Mode is off.
I Cannot Find Any Wireless Signals or Cannot Connect
If you can’t find any signals (in an area with known signals) or cannot connect to detected signals, your wireless receiver may be malfunctioning. To fix this, you will have to replace the motherboard, which is shown in [invalid guide link]
Author
with
Justin Funk
485 Reputation
3 Guides authored
USF Tampa, Team 8-5, Leahy Fall 2014 Member of USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Members
72 Guides authored
1 Comment
Connected to wifi but can't acces Internet
Mark Jeser - Reply Share
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 31
All Time: 3,051
