Up to 20% off select tools
HTC Flyer MicroUSB Port Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
3
Past 7 Days:
18
Past 30 Days:
81
All Time:
1,822
Comments: 0
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. HTC Flyer MicroUSB Port Replacement, Back Cover: step 1, image 1 of 3 HTC Flyer MicroUSB Port Replacement, Back Cover: step 1, image 2 of 3 HTC Flyer MicroUSB Port Replacement, Back Cover: step 1, image 3 of 3
      • Apply pressure along the bottom of the white panel containing the camera and push upwards.
      • It may take some effort, but it will smoothly slide off.
      Ask FixBot
    2. HTC Flyer MicroUSB Port Replacement: step 2, image 1 of 3 HTC Flyer MicroUSB Port Replacement: step 2, image 2 of 3 HTC Flyer MicroUSB Port Replacement: step 2, image 3 of 3
      • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
      • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
      Ask FixBot
    3. HTC Flyer MicroUSB Port Replacement: step 3, image 1 of 3 HTC Flyer MicroUSB Port Replacement: step 3, image 2 of 3 HTC Flyer MicroUSB Port Replacement: step 3, image 3 of 3
      • Remove the black protective piece of plastic by sliding it upwards.
      • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
      • A center 3.5mm Torx screw will be covered by "VOID" sticker.
      • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
      • Remove the protective panel by sliding it upwards.
      Ask FixBot
    4. HTC Flyer MicroUSB Port Replacement: step 4, image 1 of 2 HTC Flyer MicroUSB Port Replacement: step 4, image 2 of 2
      • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
      • Use a plastic opening tool to lever up the top half of the cover.
      • Lift the back panel up and remove it from the device.
      Ask FixBot
    1. HTC Flyer MicroUSB Port Replacement, Battery: step 5, image 1 of 2 HTC Flyer MicroUSB Port Replacement, Battery: step 5, image 2 of 2
      • Gently unfold the black tape along the top that covers the cable attachment points.
      • Leave the tape partially attached so that it can be easily re-attached.
      Ask FixBot
    2. HTC Flyer MicroUSB Port Replacement: step 6, image 1 of 3 HTC Flyer MicroUSB Port Replacement: step 6, image 2 of 3 HTC Flyer MicroUSB Port Replacement: step 6, image 3 of 3
      • Use the tip of a spudger as a lever to disconnect the four cable connectors.
      • Gently pull out these cables after releasing the back piece.
      Ask FixBot
    3. HTC Flyer MicroUSB Port Replacement: step 7, image 1 of 1
      • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
      Ask FixBot
    4. HTC Flyer MicroUSB Port Replacement: step 8, image 1 of 3 HTC Flyer MicroUSB Port Replacement: step 8, image 2 of 3 HTC Flyer MicroUSB Port Replacement: step 8, image 3 of 3
      • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
      • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
      • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
      Ask FixBot
    1. HTC Flyer MicroUSB Port Replacement, MicroUSB Port: step 9, image 1 of 1
      • Use a spudger to unclip the the wires attached to the power jack
      • The clips have a white or black relief tab that, when pressed, releases the wires.
      Ask FixBot
    2. HTC Flyer MicroUSB Port Replacement: step 10, image 1 of 2 HTC Flyer MicroUSB Port Replacement: step 10, image 2 of 2
      • Remove the two 2.5mm Torx T5 screws from both sides of the power jack panel.
      Ask FixBot
    3. HTC Flyer MicroUSB Port Replacement: step 11, image 1 of 2 HTC Flyer MicroUSB Port Replacement: step 11, image 2 of 2
      • Gently remove the power jack panel.
      Ask FixBot
4 other people completed this guide.
Author
with
Joshua
185 Reputation
1 Guide authored
USF Tampa, Team 8-5, Leahy Fall 2014 Member of USF Tampa, Team 8-5, Leahy Fall 2014
USFT-LEAHY-F14S8G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 81
All Time: 1,822
