Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Ze5000 is Not Powering On
The device will not turn on and shows no sign of power.
The Battery Charger is Not Properly Plugged In
Oftentimes, device users will mistakenly not insert the battery charger fully. Be sure to verify that the power-input is connected to the outlet and the charging-input is securely placed into the charging outlet of the HP Pavilion ze5000 device. If the charger will still not allow the device to turn on, the user may need to replace the battery charger.
The HP Pavilion Ze5000 Battery is Dead
First attempt to turn on the device using the power button. Refer to the button that is placed right above the keyboard, that is long and slim. Press on the power button for at least ten seconds to see if the device responds. If the device continues to remain unresponsive, then a replacement of the battery may be the best option. Click here to refer to the battery replacement guide.
Ze5000 is Unresponsive/Freezing
The device will not respond to any interactions from the keyboard or mouse
The Laptop’s Processor May Be Overheating
Since electronic devices have a specific range for its operating temperature, a device is likely to stop responding if the temperature is over or under that range. The device may be overheating if the processor is doing too many tasks at once, or if the internal cooling fans are malfunctioning. In the case that a possible option would be to refer to the Hardware malfunction section. Otherwise, the most likely fix would be to power down the device and wait for the laptop to cool down to room temperature.
There is an Error with Your Laptop’s Drivers
Specifically pertaining to an error with the touchpad and keyboard, the drivers may need to be reinstalled in order to have them work properly. Simply right click on the driver, and uninstall the driver. Once uninstalled, go into the CD-Drive of your computer and find the driver and reinstall it.
A Piece of Hardware is Malfunctioning
If the device is experiencing a hardware malfunction, there is a number of possible pieces of hardware that could be malfunctioning. The most likely pieces of hardware would be the cooling fan, the touchpad, and the keyboard. If any of these are malfunctioning, it might need to be replaced with a new hardware replacement. Head over to the device page for information in replacing various components.
Your Device May Have a Virus
If none of these causes seem to fix anything, then you may have a virus. Viruses can easily go undetected and require an experts approach to handling them. It is best to contact experts in this field such as GeekSquad. Once the virus is removed, make sure to install virus protection software of some sort to prevent this from happening again in the future.
Ze5000 is Running Noticeably Slower
The device is taking longer to perform tasks than it usually does
The Device has been Running for too Long
When a laptop goes too long without powering down, the system can take longer to perform functions than it should. In order to alleviate this, a simple hard reset can get your computer running smooth again. To hard reset, simply hold down the power button until your device powers off. Do not simply press the button, as this may only power down the screen. Wait five to ten minutes and then turn the device back on.
The Device Has Too Much Running At Once
Since the device is relatively old compared to today’s technology, its processing speeds are much slower than what is expected for modern laptops. Because of this, it is easy for a user to try and multitask much more than the device can handle and cause every task to move much slower. To delete these tasks, open the task manager on the device and if you are unfamiliar with any task that is currently being performed, or are aware that the task that is occurring is no longer needed, delete the task through the task manager. Also, opening up your internet browser and deleting any tabs you do not need will make the computer run smoother and faster.
Your Device May Have Too Much Occupied Storage
If your device is reaching its limit as far as storage is concerned, your computer will begin to run much slower. In order to fix this, you have two options. First, you can either go through your device and begin to delete all downloads that you don’t currently need. Doing this will free up space on the device and an increase in operating speeds. However, if everything on your device is needed regularly, you may need to purchase an additional storage device such as an external hard drive, or you can upgrade your laptops hard drive storage by replacing the current hard drive with a larger one.
The Device May Have a Virus
Ze5000 is Not Displaying Any Image
The device will not show anything on the screen leaving it black
The Device is Off
If the device is not powered on, there is no way for the device to display anything. Ensure that the device is in fact, turned on and plugged in to a power source.
The Screens Brightness is Low
If the brightness is turned to its lowest setting, the image on the screen may appear incredibly dark and very difficult to discern. The settings for brightness can be changed through prompts on the screen , however, since the screen can not actually be seen, it is best to use the brightness buttons located at the top of keyboard of the laptop.
The Screen May Be Broken
After enough time has passed and the device sees its fair share of wear and tear, the screen may not work. Either the connections to the screen are worn or the screen simply breaks, the screen will be unable to project anything. For a guide to replace a screen, follow this link .
Author
with
Eric Beaudry
823 Reputation
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 6
All Time: 407
