Up to 20% off select tools
HP Pavilion ze5000 Screen Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
17
Past 30 Days:
57
All Time:
687
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
This guide will explain how to replace the screen, assuming none of the electric connections have been damaged and the screen is the only damaged part. Some of the inner parts have sharp, metal corner and minor injury can occur if you rush through the guide.
    1. HP Pavilion ze5000 Screen Replacement, Screen: step 1, image 1 of 3 HP Pavilion ze5000 Screen Replacement, Screen: step 1, image 2 of 3 HP Pavilion ze5000 Screen Replacement, Screen: step 1, image 3 of 3
      • Remove two 5.0 mm Philips #0 screws on the hinge of the device
      Ask FixBot
    2. HP Pavilion ze5000 Screen Replacement: step 2, image 1 of 2 HP Pavilion ze5000 Screen Replacement: step 2, image 2 of 2
      Tool used on this step:
      Buy
      • Using tweezers, gently pull on the hinges to remove the plastic case connected to the hinges
      Ask FixBot
    3. HP Pavilion ze5000 Screen Replacement: step 3, image 1 of 3 HP Pavilion ze5000 Screen Replacement: step 3, image 2 of 3 HP Pavilion ze5000 Screen Replacement: step 3, image 3 of 3
      • Remove the connection between the plastic case and interior of the device
      Ask FixBot
    4. HP Pavilion ze5000 Screen Replacement: step 4, image 1 of 3 HP Pavilion ze5000 Screen Replacement: step 4, image 2 of 3 HP Pavilion ze5000 Screen Replacement: step 4, image 3 of 3
      • Remove the connection from the exposed hinge and interior of the device
      Ask FixBot
    5. HP Pavilion ze5000 Screen Replacement: step 5, image 1 of 2 HP Pavilion ze5000 Screen Replacement: step 5, image 2 of 2
      • Remove the 3.5 mm philips #00 screw on the small circuit board on the hinge
      Ask FixBot
    6. HP Pavilion ze5000 Screen Replacement: step 6, image 1 of 2 HP Pavilion ze5000 Screen Replacement: step 6, image 2 of 2
      • Remove the 5.0 mm philips #0 screw that was hidden underneath the small circuit board
      Ask FixBot
    7. HP Pavilion ze5000 Screen Replacement: step 7, image 1 of 1
      • Remove the 6 plastic caps located in the four corners of the screen and the top of the screen
      • It may be easier to use tweezers for this part
      Ask FixBot
    8. HP Pavilion ze5000 Screen Replacement: step 8, image 1 of 3 HP Pavilion ze5000 Screen Replacement: step 8, image 2 of 3 HP Pavilion ze5000 Screen Replacement: step 8, image 3 of 3
      • Unscrew the six 5.0 mm Philips #0 screws underneath the caps
      Ask FixBot
    9. HP Pavilion ze5000 Screen Replacement: step 9, image 1 of 3 HP Pavilion ze5000 Screen Replacement: step 9, image 2 of 3 HP Pavilion ze5000 Screen Replacement: step 9, image 3 of 3
      • Using a spudger, pry the plastic casing off of the screen.
      Ask FixBot
    10. HP Pavilion ze5000 Screen Replacement: step 10, image 1 of 3 HP Pavilion ze5000 Screen Replacement: step 10, image 2 of 3 HP Pavilion ze5000 Screen Replacement: step 10, image 3 of 3
      • Remove four 5.0 mm Philips #0 screws located in the corners of the screen
      • These screws locations will be close to the screws locations in step 2.
      • During reassembly, make sure you do not confuse the proper screw placements from this step and step 4.
      Ask FixBot
    11. HP Pavilion ze5000 Screen Replacement: step 11, image 1 of 2 HP Pavilion ze5000 Screen Replacement: step 11, image 2 of 2
      • Remove the four 3.5 mm Philips #00 screws from the sides of the aluminum casing.
      • There will be two 3.5 mm Philips screws on each side
      Ask FixBot
Author
with
Eric Beaudry
823 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 17
Past 30 Days: 57
All Time: 687
