Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Computer is running slowly/lagging
It takes a long time for programs to start, programs are running slowly, or the mouse skips across the screen.
Hard Reset
This will cause the computer to shut down completely, so make sure that any unsaved work is saved before you do this.
Hold down the power button, the computer will completely shutdown (instead of entering sleep mode). Wait a minute, then turn the computer back on by pressing the power button once. This may fix the issue.
Too many programs running
If you have a lot of programs running at once, your computer may not have enough memory to support them. Try running only a few things at a time, your computer's performance should increase.
Increase RAM
Your computer may be running slowly because there is not enough RAM (Random Access Memory) to run all of the programs you want to run simultaneously. You can add another RAM stick easily using this guide.
Hard drive is full/faulty
I am running out of space on my computer, I cannot download anything new or create any new files.
Not enough space for new files
You can swap the hard drive currently in your computer with a hard drive with more space. This guide shows you how to remove your old hard drive and install a new one.
Corrupted Drive
Your hard drive may be faulty. To avoid losing your files, save them to an external device and replace your hard drive.
Screen is black and unresponsive
I opened/tried to use my computer and the screen will not turn on.
Screen is broken
We would recommend proceeding with caution in this case, since this screen does contain mercury. Consider taking your device to a professional for repair.
Inadequate power supply
You can easily check this by turning the device over and seeing if the battery is in the device. If you are not confident in the integrity of your battery, plug your device into an outlet using the charger that came with your device. Press the power button and your screen should turn on.
Laptop is in sleep mode
Your device may just be in sleep mode. To start using it again, press the power button and wait for the screen to turn on.
Keyboard is not working
I am trying to type and nothing is happening/some of my keys are stuck.
Keyboard failure
If the keyboard is not working all, you can easily replace it using the following guide .
Sticky/malfunctioning keys
To replace a key on your keyboard, first, use a tool such as a screwdriver to gently pry the key off of the keyboard. Then, dampen a microfiber cloth with isopropyl alcohol and clean the key you just took off, also the spot where the key was. Snap the key back in place and trying typing.
Computer is not powering on
I'm pressing the power button and nothing is happening
Check battery
Your laptop may just need to be charged. Trying plugging it in using the charger that came with the device and pressing the power button.
Broken outlet
Your charger may be working fine, but the outlet you are using isn't. Try another outlet.
Faulty charger
Sometimes your stock charger, the one that comes with the computer, will be faulty/stop working abruptly. Try using another charger of the same specifications as the one that came with the device to charge your computer.
Malfunctioning power button
After ensuring the laptop battery is charged and the computer still isn't turning on, try replacing your power button using this guide.
Dominic DeSantis
772 Reputation
6 Guides authored
UMass Dartmouth, Team 4-5, Catania Fall 2016 Member of UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Members
72 Guides authored
0 Comments
Past 24 Hours: 11
Past 7 Days: 14
Past 30 Days: 37
All Time: 474
