HP G60T-600 CTO Power Button Frame Replacement
    1. HP G60T-600 CTO Power Button Frame Replacement, Battery: step 1, image 1 of 1
      • Failure to remove the battery before performing any replacement guide may result in electric shock.
      • Close your device, then turn it over.
      Ask FixBot
    2. HP G60T-600 CTO Power Button Frame Replacement: step 2, image 1 of 2 HP G60T-600 CTO Power Button Frame Replacement: step 2, image 2 of 2
      • Place your index finger on the ridged tab.
      Ask FixBot
    3. HP G60T-600 CTO Power Button Frame Replacement: step 3, image 1 of 1
      • Apply moderate pressure to the tab and slide it to the right.
      • While the tab is on the right, you should be able to gently slide your battery out of your device.
      Ask FixBot
    1. HP G60T-600 CTO Power Button Frame Replacement, Keyboard: step 4, image 1 of 2 HP G60T-600 CTO Power Button Frame Replacement, Keyboard: step 4, image 2 of 2
      • Unscrew the following 5mm screws with a #0 Phillips screwdriver.
      Ask FixBot
    2. HP G60T-600 CTO Power Button Frame Replacement: step 5, image 1 of 1
      • Turn your laptop over and open it up.
      • Grip your laptop firmly from both sides and use your thumbs to slide the keyboard towards the screen.
      Ask FixBot
    3. HP G60T-600 CTO Power Button Frame Replacement: step 6, image 1 of 1
      • Pull up on the top of your keyboard with medium force. It should start to pop out.
      • A plastic opening tool may facilitate this task.
      • Run your hands underneath the edges of the keyboard until it is free from the device.
      • Do not pull hard to take the keyboard out. There is a small connection that needs to be undone.
      Ask FixBot
    4. HP G60T-600 CTO Power Button Frame Replacement: step 7, image 1 of 2 HP G60T-600 CTO Power Button Frame Replacement: step 7, image 2 of 2
      • Place your thumbs on the two small, white tabs.
      • Push these tabs forward to release the connection and free the keyboard from the device.
      Ask FixBot
    1. HP G60T-600 CTO Power Button Frame Replacement, Power Button Frame: step 8, image 1 of 1
      • Similarly to how you remove the keyboard, gently pry a small section of the power button frame up.
      Ask FixBot
    2. HP G60T-600 CTO Power Button Frame Replacement: step 9, image 1 of 2 HP G60T-600 CTO Power Button Frame Replacement: step 9, image 2 of 2
      • Gently pull the white tab upwards.
      • With similar force, pull the connection out.
      • You are now free to pull the power button frame off of your device.
      Ask FixBot
    3. HP G60T-600 CTO Power Button Frame Replacement: step 10, image 1 of 1
      • Unscrew the 5mm screw holding the CD player in place.
      Ask FixBot
Dominic DeSantis
772 Reputation
6 Guides authored
UMass Dartmouth, Team 4-5, Catania Fall 2016 Member of UMass Dartmouth, Team 4-5, Catania Fall 2016
UMASSD-CATANIA-F16S4G5
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 22
Past 30 Days: 97
All Time: 542
