The printer will not print
Add blank paper to paper tray
  • The printer may be out of paper, so place blank white printer paper vertically into rear paper feeder.
Plug the USB cable into the computer
  • Plug the purple end of the USB chord into the back of the printer and the other end into a USB computer jack on the computer.
Replace the ink cartridge
Clear the paper jam
  • Gently pull out jammed paper.
Install drivers to computer
The buttons on the printer are broken/will not work
Install new buttons
The scanner/copier glass is broken/cracked
Install new scanner/copier glass
The printer will not turn on
Plug in power chord
  • Make sure the plug is securely inserted into power outlet.
Install a new motherboard
Author
with
Daniel
314 Reputation
2 Guides authored
Cal Poly, Team 9-18, Amido Fall 2012 Member of Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Members
60 Guides authored
2 Comments
Message says arm locked, clear paper jam and press print. There is no paper jame and the printer still will not do a print out. Goes through some sort of gyration but stiil will not print and the same message comes. What can I do....I cannot see a paper jam, or any jam period.
Thanks, Ronnie Treece
ronanddi - Reply Share
My printar is not print anything I just change cartridge and clean glass and all
ashish trivedi - Reply Share
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 20
All Time: 7,376
