Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Blank Screen
The screen will not display anything but the laptop is still on.
Cracked Screen
Look at the screen carefully, if there is any damage on the screen and it will not display anything while it is on, then the screen is broken. You will need to replace the screen.
Loose Wire
If there is no damage on the screen and the laptop is on, then a wire in the laptop is loose. Please take it to get repaired.
Unresponsive Keyboard
The laptop is on and the screen is displaying everything but you are unable to type in everything.
Dirty Keyboard
Use a flashlight and shine it under the keys of the keyboard at different angles. If you see dirt, dust and other things that shouldn't be there, then clean it. You can purchase compressed air canisters designed to clean keyboards of these materials along with small intricate tools to help you remove anything inside or stuck in between your keys.
Stuck Keys
When ever you press a key, if it gets stuck and keeps iterating the same key letter on your screen, you should clean it very carefully. Use small, thinly sharped objects but be carefully not to jab your keyboard and continue to carefully remove any goo surrounding your keys.
Damaged Keyboard
If you have cleaned the keys and your keyboard drivers are up to date, your keyboard may be damaged or faulty. Follow this guide to replace the keyboard.
Unable to Charge Battery
The laptop turns on but the battery will not charge.
Bad Battery
The charger plugs in but the battery will not charge. You must then replace the battery with this repair guide.
Faulty Power Adapter
Inspect power adapter plug in. Check for dust, dirty, loose or broken pieces; clean out adapter carefully without damaging any hardware inside. Plug in the adapter and if it is too loose or will not supply power to your device, then fix it with this repair guide.
Device Will Not Turn On
No matter how much you try the laptop will not turn on.
Over Heating
Touch the bottom of the laptop, if it is very hot, put it aside and leave it alone until it cools. If it still doesn't work after 10-20 minutes, make sure that you are working on a well ventilated hard surface and not a cloth surface or on your skin. Make sure that the vent holes aren't covered. In addition, check that you don't have too many files running because it could be taking up too much storage. Close unnecessary files and see if it cools down.
Power button not working
Press and hold the power button down for 5 seconds, if it does't work, feels too loose or is stuck, then you need to replace the power button or carefully clean it.
Unable to Connect to Internet
If your internet is working but the laptop is unable to connect to it.
Internet Will Not Connect
Check all settings in the laptop so it can enable internet connection. If this does not work, then you may have to replace the Wi-Fi card which is found in Step 9 of the motherboard replacement guide.
Author
with
Brenda
2 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 852
