HP Chromebook 11-v011dx Key Board Replacement
  1. HP Chromebook 11-v011dx Key Board  Replacement, Key Board: step 1, image 1 of 3 HP Chromebook 11-v011dx Key Board  Replacement, Key Board: step 1, image 2 of 3 HP Chromebook 11-v011dx Key Board  Replacement, Key Board: step 1, image 3 of 3
    • Wedge the spudger between one of the black rubber caps on each of the four corners on the bottom of the HP Chromebook 11-v011dx.
    • Lift up the black rubber cap until it is completely removed.
    • Repeat this until all four of the black rubber caps are removed.
    Ask FixBot
  2. HP Chromebook 11-v011dx Key Board  Replacement: step 2, image 1 of 2 HP Chromebook 11-v011dx Key Board  Replacement: step 2, image 2 of 2
    • Locate the two smaller black rubber caps on the top corners of the HP ChromeBook 11-v011dx. Wedge the spudger between one of them.
    • Lift up the small black rubber cap until it is completely off.
    • Repeat this step one more time to remove the other small black rubber cap on the other side.
    Ask FixBot
  3. HP Chromebook 11-v011dx Key Board  Replacement: step 3, image 1 of 2 HP Chromebook 11-v011dx Key Board  Replacement: step 3, image 2 of 2
    • Locate the eleven screws on the bottom the HP ChromeBook. Six are located under the larger black rubber caps and the others are in different locations.
    • Use a Phillips #0 screwdriver to remove eleven 1.3mm screws.
    Ask FixBot
  4. HP Chromebook 11-v011dx Key Board  Replacement: step 4, image 1 of 3 HP Chromebook 11-v011dx Key Board  Replacement: step 4, image 2 of 3 HP Chromebook 11-v011dx Key Board  Replacement: step 4, image 3 of 3
    • Make sure to do steps 1-3 or it will be impossible to lift up the key board and you may also do damage to the hardware.
    • Wedge the spudger between the key board and the bottom panel, carefully go around the keyboards edges gently.
    • Lift the spudger a little in the front of the keyboard until the key board lifts up.
    • With your hands, slowly and carefully lift the key board up.
    Ask FixBot
  5. HP Chromebook 11-v011dx Key Board  Replacement: step 5, image 1 of 1
    • Locate the black tab that holds a wire in place that keeps the keyboard connected to the mother board.
    • Slowly unplug this wire that connects to the key board.
    Ask FixBot
Kyle DeMello
542 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 22
All Time: 503
