Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Will Not Turn On
If device fails to turn on or won't charge at all.
Battery
If the device will not turn on, try to charge it at least for 3 to 4 hours using a USB to Micro USB plug to your laptop or PC. Remember Battery will last up to 4 hours when connected wireless and up to 12 hours when connected through Aux-in audio jack.
If charging does not work, you may need to replace your battery. Here is the link to a repair guide that shows you how.
Charging
If the devices fails to charge, try a different USB port in your laptop or PC. If the problems continues try a different micro USB cord.
Bluetooth Connection Issue
If the device fails to connect with other devices via Bluetooth.
Connections
To begin with, make sure you are using the right devices that can connect to the HMDX JAM wireless. If so, then turn off both devices, wait 15 seconds, turn both back on and make sure that the lights on the HMDX Jam are flashing. Ensure device is showing that it is searching for a host. Also, make sure your other device's Bluetooth is on and is searching.
Adjusting Volume Issue
The loudness of the audio output does not increase or decrease when volume button is pushed.
Max Volume
When at maximum volume, the sound fills the room; but the audio tends to be to harsh to the ears. The speakers perform the best at medium volume.
When Connecting to Multiple Devices
When the speaker is connected to more than one device, the sound is noticeably improved because the devices pick up mid and lower frequency sounds. However adjusting the volume on one speaker (when paired) doesn't change the volume of the other.
Device Slides Off Surfaces
Speaker does not stay placed in one position on a surface. Device slides off of slightly inclined surfaces or shifts position very easily.
Rubber Base
This may be due to the wear and tear of the rubber base of the speaker. The base may be worn out and has lost its grip to stay placed in one position on a surface. If you want to restore the sturdiness of the speaker you need to replace the rubber base cover. This guide shows you how.
Factory Reset
Speaker is not pairing with Bluetooth devices or is showing that it is paired but is not playing music from Bluetooth device.
Language Reset
hxp250
hold minus sign down for a moment then push plus sign once to cycle to next language in cycle.
Reset
To reset your speaker press and hold play/pause for 5 seconds or so until you hear a sound or the red light flashing. Note: Restoring the speaker's factory defaults erases all paired Bluetooth devices from the speaker's memory.
Author
with
idonel louidor
1 Reputation
0 Guides authored
USF Tampa, Team 1-1, Blackwell Winter 2015 Member of USF Tampa, Team 1-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G1
4 Members
24 Guides authored
275 Comments
cannot connect my speakers with my laptop through bluetooth.
dilipvira1 - Reply Share
yoo i tried to connect the aux cord to a ipod nano i had but it keeps only connecting to bluetooth, my phone was crushed so idk what else it would be connecting to. please help!
mcearthessence210 - Reply Share
I'm having a similar problem with my regular iPod. Connect the aux cord, and the iPod is playing, but can't get any sound. !#^&@@.
alexis arnold - Reply Share
what ever blue tooth device you got connected to it turn off the blue tooth on it or disconnect it from settings. also make sure the 3.5 jack is fully pushed in it should override the blue tooth and work like any normal speaker
dac96 - Reply Share
Try resetting it. If it doesn't work then it my be the cord. Cheap aux cord don't last long or sometime are too small. Try testing somewhere like a
Victor cheese - Reply Share
Past 24 Hours: 1
Past 7 Days: 13
Past 30 Days: 90
All Time: 549,520
