Up to 20% off select tools
HMDX Jam Battery Replacement
Views: 99K
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
173
All Time:
99,396
Comments: 23
5 comments on steps, 18 guide comments.
Go to guide comments
Completed: 42
42 people have marked this guide "completed." Will you be next?
Favorites: 4
4 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 25 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Outline what you are going to teach someone how to do.
    1. HMDX Jam Battery Replacement, Opening speaker: step 1, image 1 of 1
      • Use the plastic opening tool to pry off the rubber cover at the bottom of the speaker.
      Ask FixBot
    2. HMDX Jam Battery Replacement, remove rubber cover: step 2, image 1 of 1
      • Gently remove the rubber cover to expose the screws. If necessary, poke holes through the glue residue to expose the screw heads.
      Ask FixBot
    3. HMDX Jam Battery Replacement, Remove screws: step 3, image 1 of 1
      • Once you have exposed the screws, use a #1 Phillips screwdriver to remove the four 9 mm screws.
      • It would be wise to use a magnetic mat for the screws for safekeeping.
      Ask FixBot
    4. HMDX Jam Battery Replacement, Exposing Battery: step 4, image 1 of 1
      • Once you've removed the screws, open the case slowly. The battery is covered in blue packaging.
      Ask FixBot
    5. HMDX Jam Battery Replacement, Removing Battery: step 5, image 1 of 1
      • Very gently remove the battery from the motherboard.
      Ask FixBot
    6. HMDX Jam Battery Replacement, Remove battery attachments: step 6, image 1 of 2 HMDX Jam Battery Replacement, Remove battery attachments: step 6, image 2 of 2
      • Use a solder gun to remove the battery attachments from the motherboard.
      Ask FixBot
42 other people completed this guide.
Author
with
Prince Tendai Dzonga
680 Reputation
1 Guide authored
USF Tampa, Team 1-1, Blackwell Winter 2015 Member of USF Tampa, Team 1-1, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G1
4 Members
24 Guides authored
18 Guide Comments
Looks like a great solution to fixing the speaker with a battery with a short life span. But what's the amperage of the lithium barberry and where can I purchase one ?
Stephen Lavizzo - Reply Share
Did you ever find out where to purchase a new battery for it?
DJ Ethics - Reply Share
Hey Stephen. Can you tell me where i can buy a replacement battery for my P120
Lynchfield Daniel - Reply Share
On my Model: HX-P240A
KANYO 383541P 3.7V
520mAh 1.924Wh
534114364A17142
minhngoctruong - Reply Share
My Bluetooth speaker just has a rubber suction on the bottom. There is no area to replace a battery. Is there any way to reset I?
bdale46 - Reply Share
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 173
All Time: 99,396
