Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Basket Won’t Close
 Following the food being put on the tray and trying to put it in the fryer, the basket wouldn’t stay closed.
Latch is Broken
The latch area could be dirty; first, establish that the latch area is clear and not blocked by any debris. If the area is clean, the latch and hinge may need to be replaced.
Damaged Basket
This product does have a historical reputation for being faulty out of the factory, so some parts just need to be completely replaced. This includes replacing the basket with a new one if a factory defect is present.
Tray Doesn't Fit
The tray may be the wrong size or was put in wrong. Make sure you follow the arrows that are provided on the back of the tray. If the rubber feet are unstable they can be replaced.(Tray Rubber Bumper Replacement)
Handle Breaks Off
When trying to pick up the basket, the handle broke off.
Screws Loose
This could require a simple tightening, but in the case that the screws are missing or defective, the screws will need to be replaced.(Handle Replacement Guide)
Fan Doesn’t Turn
The air fryer turns on but stays quiet (the fan makes a noticeable noise).
Air-fryer needs to be reset
This could be a software issue and can be remedied by a factory reset which will reboot the system and the fan will start working. There should be a reset button on the bottom of the fryer. Press that button and it should reset.
A Fuse is Broken
The fan will not turn if the fuse is faulty or has blown. It will need to be changed.
The Timer has not been set
The fryer will not run if the timer is not set; therefore, the fan will not start if the timer is not set.
Heating Coils Stay Cool
  After running the air-fryer, the food stayed cold.
Temperature Settings set at Low-Temp
This can be caused by the heat setting being on low; this will be as easy as changing the heat setting to high. First, you will need to press the ‘temp/time’ button. Then use the ’+’ and ‘-‘ buttons to adjust the temperature. If the problem persists, the cause is something else.
The Fryer Needs to be Reset
Resetting the fryer is as easy as locating the button on the bottom of the air fryer and pressing it.
Faulty Heating Element
The heating element may be defective and need to be replaced by a working part.
Screen Not Working
Going to use the air fryer and couldn’t control the settings.
Defective Switches/ Control Board
First, ensure that the screen is not dirty, this could affect the performance of the machine. If the screen still does not work properly, any of the components could be broken. This includes the buttons and control board, so one or more of these parts might need to be replaced.(Screen Circuit Board Replacement Guide)
Panel is Dislodged from Fryer
Gently push the screen back into place.
Faulty Power Chord
If the fryer is fully plugged into the outlet and still won’t work, the power chord supplied is defective and will require replacement.(Power Chord Replacement Guide)
In order to access these parts, you will need to remove the grey cover from the top of the fryer. (Grey Top Replacement Guide)
Air-Fryer Moves Around on Counter
The fryer slides around the counter or is unsteady.
Defective or Missing Rubber Bumpers
This is a problem that requires part replacement.(Rubber Bumper Replacement Guide)
23 Comments
Temp guage stays at 1 minute and counts down. Will not increase pressing the + buttin. Hiw can I fix it?
Yvonne Di Placido - Reply Share
Temp guage stays at 1 munute and counts down. Will not increase by pressing the + button. How can I fix it?
Why dies is give me a code C007
Petra Rodriguez - Reply Share
My air fryer has stopped turning itself off or to cool down mode when you remove the basket and continues to heat and blow air.
NorMor - Reply Share
When I pull basket out machine come on and when basket closed machine won't come on.
David Whitehead - Reply Share
Past 24 Hours: 13
Past 7 Days: 84
Past 30 Days: 371
All Time: 28,076
