Gourmia GAF536 Handle Replacement
    1. Gourmia GAF536 Handle Replacement, Handle: step 1, image 1 of 2 Gourmia GAF536 Handle Replacement, Handle: step 1, image 2 of 2
      • Make sure the device is turned off and let it cool down.
      • Remove the basket and tray from your air fryer.
      Ask FixBot
    2. Gourmia GAF536 Handle Replacement: step 2, image 1 of 3 Gourmia GAF536 Handle Replacement: step 2, image 2 of 3 Gourmia GAF536 Handle Replacement: step 2, image 3 of 3
      • Locate the screws inside the basket.
      • 4x PH02 Screws: 15mm x 5mm
      Ask FixBot
    3. Gourmia GAF536 Handle Replacement: step 3, image 1 of 3 Gourmia GAF536 Handle Replacement: step 3, image 2 of 3 Gourmia GAF536 Handle Replacement: step 3, image 3 of 3
      • Once the screws are removed separate the handle from the basket.
      • Locate the single screw on the handle.
      • 1x PH02 Screw: 15mm x 5mm
      Ask FixBot
    4. Gourmia GAF536 Handle Replacement: step 4, image 1 of 3 Gourmia GAF536 Handle Replacement: step 4, image 2 of 3 Gourmia GAF536 Handle Replacement: step 4, image 3 of 3
      • Remove the screw.
      • Gently pull on the handle with the force needed.
      Ask FixBot
    5. Gourmia GAF536 Handle Replacement: step 5, image 1 of 1
      • After following these steps you will successful remove the handle.
      • Make sure you have all the equipment when going to replace the handle.
      Ask FixBot
3 other people completed this guide.
1 Guide Comment
Surprised they dont do a recall! The screws can potentially work itself out and unto the food
Jo Avridge - Reply Share
Past 24 Hours: 5
Past 7 Days: 38
Past 30 Days: 104
All Time: 1,877
