Up to 20% off select tools
GoPro Hero3+ Black Edition Battery Replacement
Views: 3.4K
View statistics:
Past 24 Hours:
4
Past 7 Days:
22
Past 30 Days:
115
All Time:
3,429
Comments: 2
2 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 minute
Difficulty: Very easy
Introduction
Go to step 1 ↓
Can't seem to charge your battery? It may be time to replace it. This guide will walk you through the simple steps to access and replace your GoPro battery.
    1. GoPro Hero3+ Black Edition Battery Replacement, Battery: step 1, image 1 of 1
      • Pull the tab on the back of the device to release the back cover. It should come right off.
      • The device pictured does not include the back cover.
      Ask FixBot
    2. GoPro Hero3+ Black Edition Battery Replacement: step 2, image 1 of 1
      • Use the battery tab to pull the battery out of the device.
      Ask FixBot
      • Remove the battery from the slot.
      Ask FixBot
4 other people completed this guide.
Author
with
Chad Carlson
1,148 Reputation
2 Guides authored
Cal Poly, Team 6-15, Maness Spring 2015 Member of Cal Poly, Team 6-15, Maness Spring 2015
CPSU-MANESS-S15S6G15
4 Members
84 Guides authored
2 Guide Comments
it did not fix it at all
nogo - Reply Share
WOw thanks
Thomas Maloney - Reply Share
Past 24 Hours: 4
Past 7 Days: 22
Past 30 Days: 115
All Time: 3,429
