Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Device Does Not Turn On
You can’t get the duck to wake up.
Charge the duck fully to 100%
To charge the duck, align the duck with the green charging dock and make sure the dock is plugged into the outlet. If the duck is not charging, view the guides on how to replace the battery. When the heart is yellow, the battery is low and when it is green, the battery is sufficient for functioning.
Heart power button needs to be replaced
The button to turn the duck may be broken, click here to replace the button.
Battery needs to be changed
To change the battery, use the guide provided. One reason the battery would need to be replaced, would be because the motherboard and the battery pack aren't fully connected. Use the same guide to replace the battery.
No Connection Between Edwin the Duck and Smart Devices
Your device cannot find the duck via Bluetooth, or it’s experiencing problems staying connected to the duck.
Device may not be compatible
Not all wireless devices use Bluetooth. Your device may also be outdated as the app requires iOS 6.0 or later for Apple devices, and version 4.4.2 and up for Android devices. However, please note Edwin the Duck is known for having compatibility issues with Android Devices. If possible, try to use a different device.
Bluetooth is not enabled on your mobile device
To enable Bluetooth, go into the settings of your mobile device and make sure Bluetooth is turned on. Depending on your device, you should see Edwin the Duck as one of the listed Bluetooth devices that you can connect to.
Mobile device and duck out of range
Bluetooth devices require you to be within a specified range. If you are outside the range, you may experience disconnections and interruptions with the connectivity to the device.
Audio is Too Low or Does Not Work
After prolonged use or playing in the bath, your duck’s speakers don’t work properly anymore.
Water Damage
The damage may have caused the motherboard to break and will cause the duck to stop making sounds. To fix this issue, see the guide how to replace the motherboard
Speakers needs to be replaced
Click here to see the guide to replace the speaker
Does Not Charge
Your duck does not seem to be charging at all.
Make sure the cable is fully connected to the charging dock and power brick
When opening the the duck that contains the motherboard, make sure to not pull hard when separating the two parts. Wires are connected to both ends and if pulled with force, the wires will break damaging the function of the duck.
Replace mirco usb cable and power brick
The micro usb cable or power block can be the issue. If so, it's best to order or buy new ones with the same charging entry to the duck.
Battery needs to be changed click here to see how to replace the battery
In order to change the battery, you'll need to remove the skin of the duck, unscrew all the screws, to get the motherboard center of the duck. From there you will need to hold the battery and gently move it back and forth to remove with ease. This will be complicated to do because the battery is glued onto the side.
LED Lights Do Not Work
One of the duck’s lights is not turning on like it used to.
LED lights needs to be changed
If the duck is making noise and responding to motions and the app, but the light isn't working, use the following guide to see how to replace the LED light.
Author
with
Nadia Dobrogorskaya
158 Reputation
1 Guide authored
UW Tacoma, Team S1-G4, Rose Fall 2017 Member of UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
3 Members
36 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 35
All Time: 4,419
