Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Screen Is Unresponsive
Screen is not responding properly or not responding at all.
Too Many Apps Open
If the screen is responding very slowly or not at all, you could have too many apps open at one time. Close all your apps, then restart your tablet, and check if it is still responding slowly.
  • On most Android devices, you can access the recent apps screen by tapping the square or rectangular button usually located at the bottom of the screen. This button is also known as the Overview or Recent Apps button. Swipe each app upwards to close the app. Alternatively, there may be a Close button (indicated by an X symbol) or a Close All Apps option.
Software Glitch
If the screen is unresponsive, a software glitch might be the cause. Try restarting the device to clear any temporary software issues.
Touch Screen Is Not Calibrated
Incorrect touch screen calibration can lead to unresponsiveness. Check the device settings to recalibrate the screen:
  • Step 1: Find the Settings app on your Dragon Touch Y88X Plus tablet. It is represented by a gear icon.
  • Step 2: Look for the Display or Display & Brightness option within the Settings menu.
  • Step 3: Search for an option related to Screen Calibration or Touch Settings
  • Step 4: Tap on the Calibration option, and you may be prompted to follow on-screen instructions. This will involve touching specific points on the screen or adjusting a slider. Follow the instructions until they are complete to finalize recalibration.
Once these steps are complete, your tablet's screen should be recalibrated.
Screen Is Damaged
If the device has been dropped or damaged otherwise, the screen may be cracked or broken, which could cause it to become unresponsive. This can be solved by replacing the screen using this guide.
Faster Battery Drain
Overtime the battery life drains faster.
Too Many Apps Open
Excessive background processes or apps running in the background could contribute to faster battery drain. Check and close unnecessary background apps.
Software Is Outdated
Ensure that the tablet's operating system and apps are up to date. Sometimes, outdated software can cause increased power consumption.
To see if your device has any system updates, follow these steps::
  • Step 1: Check for system updates
    • Open the Settings app on your Dragon Touch Y88X Plus tablet.
    • Navigate to System or About tablet.
    • Look for the Software Update or System Update option.
    • If there's a system update available, follow the on-screen instructions to download and install it.
  • Step 2: After installing the system update, it's a good practice to restart your tablet to ensure that all changes take effect.
After following these steps, your tablet's system software should be up to date.
Expanded Battery
If the backplate pops off and you see a fat silver sac, then the battery has expanded, and you must replace the battery and pop the backplate back on using this guide.
Faulty Battery
If there are no visual deformities with the battery, then the battery may be faulty due to age or wear and tear. This can also be solved by replacing the battery using this guide.
Audio Is Distorted
Audio is providing unusual sounds or no sounds at all.
Low Volume Levels
Ensure that the volume settings are configured correctly. Adjust the volume levels using the buttons on the side of the tablet and check if the distortion persists.
Faulty headphones
Firstly, try using different headphones to ensure that the headphones themselves are not the underlying issue.
Software Audio Issues
Check for software-related audio issues by restarting the device. Sometimes, glitches in the operating system can cause audio problems.
Loose Audio Jack
Audio may be distorted because of a loose audio jack or foreign bodies like lint or dirt in your audio jack. Check for dirt or lint and then use a thin round tool such as tweezers and some rubbing/isopropyl alcohol to clean out the headphone jack.
If the problem continues, you may need to replace the motherboard.
Camera App Shows Black/Distorted Image
Camera app shows black screen or distorted image.
Camera App Is Outdated
Ensure that the camera app is updated to the latest version. Outdated apps may have compatibility issues leading to camera malfunctions. You can check if the tablet has any system updates in the Settings, which will provide any updates to the camera app.
  • Step 3: Open the camera app on your tablet and check for any new features or improvements.
After following these steps, your tablet's camera app should have the latest version installed.
Incorrect Camera Settings
Try resetting the camera settings to default. Incorrect camera settings can sometimes cause display issues.
To reset the camera settings, follow these steps:
  • Step 1: Locate the camera app on your Dragon Touch Y88X Plus. You can usually find it in the Apps drawer or on your home screen.
  • Step 2: Once the camera app is open, look for a gear icon or three dots (ellipsis) usually in the top or bottom corners of the screen. Tap on this icon to access the camera settings.
  • Step 3: Within the camera settings, look for an option like Reset, Restore Defaults, or Reset Settings. The exact wording may vary depending on the camera app and the version of Android your tablet has installed.
  • Step 4: When you find the reset option, the app might ask for confirmation before proceeding. Confirm that you want to reset the camera settings.
  • Step 5: After resetting the settings, it's a good idea to close the camera app and reopen it to apply the changes.
After following these steps, your device's camera app settings should be completely reset.
Dirty/Obscured Lens
The lens of the device might have debris covering it, preventing an image from being displayed correctly on the device. Ensure that the lens of the camera is clean by using a soft-bristled brush and/or microfiber cloth with rubbing/isopropyl alcohol to wipe the lens.
Damaged Camera
Due to poor packaging or a manufacturing error, your camera may be damaged even before you’ve used the tablet. In that case, you should return it or replace the camera. If the lens is damaged post unpackaging, then replacement is necessary. You can replace your device's camera using this guide.
Tablet Will Not Charge
When the charger is plugged in, the tablet will not charge/does not show it is charging.
Damaged Charging Cable
Examine the charging cable for any visible damage. A frayed or damaged cable can prevent proper charging.
Faulty Power Source
Verify that the power source, such as the electrical outlet or USB port, is functioning correctly. Try a different power source to eliminate this as the cause.
Dirty charging port
Your tablet not charging may be due to lint or dirt in your charging port. Using a toothpick or a different tool of choice and isopropyl rubbing/alcohol, carefully clean out your charging port.
Faulty charging port
If cleaning the port did not work, then your charging port may be damaged. Replace the motherboard as the charging port is soldered on.
Device Crashing/Restarting Randomly
Tablet randomly turns off or restarts on its own.
Ensure that the tablet's operating system and apps are up to date. Software bugs can sometimes cause random crashes.
Battery Level is Too Low
The tablet's software may be giving a faulty reading for the battery charge. Ensure the tablet is charged completely before diagnosing further. If the problem persists, allow the tablet to run out of battery completely and charge it back to full.
Faulty Motherboard
If your device is continuously crashing or restarting, then chances are there is a problem with the motherboard in your device which means you will have to replace the motherboard.
Important: Motherboard replacement is a higher-level repair and will require concentration and patience. Replacing a motherboard is a last resort.
You can replace the motherboard of your device using this guide.
Kath Landers
1 Reputation
0 Guides authored
7 Comments
Sound doesn't work
mona moore - Reply Share
the on and off switch was pushed into the tablet. Now the battery will show up to say its charging or charged but i can not turn the tablet on. I took it apart and the on and off switch fell off and the metal part i touched with a knife to see if it would turn on and the metal fell off. what do i do to fix it
tammywilliams22200074 - Reply Share
Tablet will turn on and load but won't go past that. Keeps cycle back to the loading
kim Hatcher - Reply Share
It come on ans stop at the dragon touch and the it. For hr. But that as fare as it will go.
Thomas j tolbert - Reply Share
My daughters sound just stopped working. I did a reboot and still nothing.
Melissa Bismack - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 34
All Time: 4,514
