Dragon Touch Y88X Plus Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
21
Past 30 Days:
74
All Time:
573
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 20 - 40 minutes
Difficulty: Difficult
Introduction
Go to step 1 ↓
If the battery in your Dragon Touch Y88X Plus tablet is having power issues, use this guide to replace it. This repair requires a soldering iron to remove the connectors of the battery. You may also want to use adhesive tape to further secure the battery after replacement. If you need any additional help with the process of soldering, you can refer to the How To Solder and Desolder Connections guide.
Tools
    1. Dragon Touch Y88X Plus Battery Replacement, Battery: step 1, image 1 of 1
      • Remove the back case using a plastic opening tool or spudger.
      • Start at the corners and work your way around the perimeter of the tablet.
      • Be gentle to avoid damaging the case or any internal components.
      Ask FixBot
    2. Dragon Touch Y88X Plus Battery Replacement: step 2, image 1 of 2 Dragon Touch Y88X Plus Battery Replacement: step 2, image 2 of 2
      • Identify the tablet's battery. It is usually a flat, rectangular component connected to the motherboard.
      • Carefully peel the old battery from the adhesive using your iFixit pry tool.
      • Be very cautious not to puncture the battery if yours has expanded . If the battery is swollen, read the article on What to do with a swollen battery for assistance.
      Ask FixBot
    3. Dragon Touch Y88X Plus Battery Replacement: step 3, image 1 of 2 Dragon Touch Y88X Plus Battery Replacement: step 3, image 2 of 2
      • Use a soldering iron to disconnect each connector individually from the motherboard.
      Ask FixBot
    4. Dragon Touch Y88X Plus Battery Replacement: step 4, image 1 of 1
      • Remove any adhesive from the battery.
      • Remove the battery.
      Ask FixBot
2 other people completed this guide.
Bavly Aziz
195 Reputation
1 Guide authored
UMass Dartmouth, Team 1-4, Petersen Fall 2023 Member of UMass Dartmouth, Team 1-4, Petersen Fall 2023
UMASSD-PETERSEN-F23S1G4
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 21
Past 30 Days: 74
All Time: 573
