Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Laptop Will Not Turn On
The laptop will not power on or has a short lifespan.
Faulty Charging Port Internally
Make sure the charging port has no internal damage. A light should appear if the cable is charging successfully. If the the light does not appear you might have a faulty power adapter.
Faulty Battery
Check to see if anything spilled on the laptop, or if there was any physical damage to the battery. If the laptop dies quickly, does not charge to 100%, or stays completely dead, then replace the battery. Replace the battery by following this guide.
Hinge Separated From Computer Brackets
The right hinge is disattached to the rest of the laptop and as a result, the screen is misaligned
Disattached From The Screw
Check to see if the hinge has been removed from the built in screw that holds it in place. Try to reattach it to the screw as carefully as you can as there are internal wires and fragile parts surrounding the hinge.
Computer Is Overheating And Making a Weird Noise
Device is overheating or making a weird noise when being used.
Dust Accumulation
If your fan is constantly overheating check if there is dust blocking the fan airway. After a good amount of time the computer's fan can easily collect dust. Make sure this collected dust is cleaned out properly and consistently. To access the internal fan follow this guide.
Vent Obstructed
While the computer is running check if it is making a weird noise. If so check the area where the fans air is distributed. This area may be physically damaged causing the fan to not work properly. To fix this, replace any external hardware that may be getting in the way of the fan working properly.
Computer Freezes and Error Messages Appear
Dell XPS M1330 experiencing unwanted delays and receiving troubling notifications .
Accumulated Viruses
Device may have contracted viruses ''from websites that are unsecure. This could also come from downloading from unsecure sources, or opening up emails and other links that are attached with viruses. Reset and reinstall to allow the device to delete these viruses and all other information for a clean slate.
Computer Is Loading Slower Than Usual
If your computer is experiencing a slow loading time this may be due to a build up of unneeded documents. To help this situation resetting your computer will bring the computer to its previous state without losing any personal data.
Unable To Add More Documents or Photos
Dell XPS M1330 storage is unable to save new files, or is unusually slow.
Faulty Memory Card
Memory card sustained physical damage or internal damage. If error messages pop up when attempting to save files then the card may need to be replaced.
Storage Capacity Filled With Unknown Files
Try to delete unused files or applications. If Storage is filled to capacity with unknown files, then you may need to do a memory sweep to delete these files. One area these can be located in is the downloads folder. You can also clear your history and cache to help aid the process.
Christopher Stangarone
125 Reputation
0 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 31
All Time: 672
