Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Shutting down without warning
Your laptop shuts off in the middle of an important task constantly.
Battery is not charging properly
The battery may be faulty and will need to be replaced.
A replacement of the power adapter port may be necessary due to the power connection between the charger and the battery.
Too much memory
One of your programs may be using too much memory and causing your computer to shut off.
Too much Cloud dust
There may be cloud dust in the back of the air vent. Replacing the fan and/or the heat sink may be required
Black screen
Your screen will not show anything at times.
Faulty Blacklight
You may need to buy or replace a new backlight.
Run diagnostic tool to check hardware on the computer
Your hardware could have issues you are unaware of; you can run a diagnostic test to check for problems.
Light indicators on without input
All of the lights are on and working on your computer — except the screen.
Faulty Memory Modules
Restart the memory modules, if they do not work after being restarted it is most likely a mainboard issue.
Faulty Mainboard
If this is the problem you will need to replace the mainboard or get a new laptop.
Overheating
The laptop begins to overheat when in use.
Temperature varies between 48 and 52 degree celsius.
Buy some arctic silver paste and use it instead of the cheap thermal pads that come with every Dell laptop and apply it between the CPU and the heat sink.
Slow fan speed
Take the fan out and clean it so that there is no dust on the fan.
Use compressed air to blow out the dust in the fan.
A replacement of the fan may just be the better option.
Water damage
Having trouble with laptop performance after accidental water spills.
Faulty inputs
Water damage can greatly affect the functionality of the laptop. Check for connections between inputs and outputs.
Check for a warranty for a new replacement.
Please do not use a heat lamp, or anything that produces heat, to dry any of your electronics. It can cause more damage.
Additional Information
Link to troubleshooting page: Dell Inspiron 14 5100
1 Comment
My laptop turns on but am not able to get to screen where I can put in my pass code is there anything I can do?
Ronald Archie - Reply Share
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 36
All Time: 2,710
