Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Chromebook 3110 will not charge
Chromebook 3110 does not charge while plugged in.
Fault in CMOS
The Chromebook 3110 may not be charging correctly due to an error in the motherboard. Charge the Chromebook for approximately 25 minutes while it is powered off, then you attempt to reset the EC (Embedded Controller) by holding down the Power button (located on the side of the machine), the Round Arrow (top row of keyboard, fourth from the left) and the Escape key for three seconds. If the system boots to an "! OS missing" error, press and hold the Round Arrow and Power buttons to reboot the device.
Faulty Charger
First, check to ensure that your charger is correctly plugged into both the wall and the device. If these connections are sound, proceed to Faulty Battery below to help isolate the problem. If the battery is not the issue, your charger is faulty and needs to be replaced.
Faulty Battery
Remove the backplate from the Chromebook 3110 using a #00 Phillips screwdriver for all the screws. Then unscrew and remove the battery from the Chromebook, and leave it unplugged for 10-15 minutes. Once that is done, plug the battery back in, reattach all the screws, and attempt to power on the device. If this fails, your battery may be faulty and in need of replacement.
Chromebook 3110 webcam not functioning
Chromebook 3110 camera not detecting open case and camera app not opening.
Camera App Data Corrupted
Begin by uninstalling and reinstalling the camera application on your Chromebook. Google's precise instructions for doing so work best for this fix:
Uninstall / Reinstall
Unidentified Hardware Issue
If reinstalling the camera app does not resolve the issue, try referring to Google's Chromebook Camera doesn't work troubleshooting page.
Chromebook 3110 Lagging Online
Chromebook 3110 greatly slowing down while using online browsers.
Too Many Tabs Open
When you are working on something like a paper or a project, and you have several tabs open, one of the things you might notice is that the tabs you have open are working slower. This is because the more tabs open, the more the wifi has to be shared between the tabs.
To fix the problem, close each of the tabs once you are done with them. You can also see if you have any programs that are running in the background.
Too Many Applications
Programs, games, and other applications take up large amounts of space on the hard drive, and with the 32GB of space available, having any amount of applications can slow down the Chromebook. Some applications are constantly running in the background, and those will be taking up battery power as well as bands of wifi.
To fix the problem, go in and see if you have any unused applications. If you do, remove them to free up space on the drive. If you have any open applications that you are not using, close them properly and make sure they are not taking up any background wifi or information.
Chromebook 3110 not saving files
Chromebook 3110 files not saving locally or becoming corrupted on device.
Not Connected to Wifi
When you are trying to download a file, the size of the file can often pose problems. One of which being, there is not enough wifi to download the file onto the device.
If this is the problem, one of the ways to fix it is to check your wifi settings and reset them. Try disconnecting and then reconnecting to the wifi.
No Space on Device
Keeping in mind that the Chromebook does not have a lot of space, downloading files onto the drive might not work.
Look at what files are already on the device, and see if you can delete any of the extra ones you aren’t using. You can also see if you have any programs you aren’t using. One of the ways to make space on any device is to remove unused applications.
Chromebook 3110 crashing
Chromebook 3110 freezes or shuts off entirely during use.
Software out of date
Crashing that occurs on the Chromebook 3110 could occur due to the operating software (ChromeOS) being outdated or corrupted. Try following Google's instructions on Updating your Chromebook's operating system first for updating the operating software, and then if necessary, Resetting your Chromebook.
Battery depleted
The system may freeze or shut off as a result of low battery; try plugging in the Chromebook and restarting the device. If the battery was recently charged, or this continues to occur while plugged in, please refer to either Chromebook 3110 will not charge above, or System overheating below.
System overheating
The Chromebook 3110 has automatic safeguards in place to prevent damage to hardware components and danger to the user. Using a #00 Phillips screwdriver bit, unscrew all screws from the back plate of the Chromebook. For your convenience, the arrangement of these screws is pictured below.
Overheating can be caused by a variety of factors, the most common of which is an accumulation of dust. If clumps of dust are present, try to remove them carefully with tweezers or a compressed air canister. If no dust is present, carefully examine the battery for faults. If any of the battery's cells are inflated, unscrew the assembly using the same #00 Phillips screwdriver bit, unplug the routing cables (pictured below), remove and safely discard the battery and purchase a replacement.
Author
with
Kyle Neblo
201 Reputation
1 Guide authored
Marist, Team 1-6, Chaterdon Spring 2023 Member of Marist, Team 1-6, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G6
2 Members
24 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 56
All Time: 2,559
