Dell Chromebook 3110 Battery Replacement
  1. Dell Chromebook 3110 Battery Replacement, Battery: step 1, image 1 of 1
    • Set the laptop upside down on a clean work space.
    Ask FixBot
  2. Dell Chromebook 3110 Battery Replacement: step 2, image 1 of 1
    • Remove nine 4 mm screws from the back cover of the laptop using a Phillips #00 screwdriver.
    Ask FixBot
  3. Dell Chromebook 3110 Battery Replacement: step 3, image 1 of 1
    • Using an opening pick and a plastic opening tool, begin to separate the back cover from the laptop.
    • Using your hands, fully remove the back cover.
    Ask FixBot
  4. Dell Chromebook 3110 Battery Replacement: step 4, image 1 of 1
    • Unplug the battery from the motherboard by gently pulling on the cable header from the motherboard toward the battery.
    • Using the Phillips #0 screwdriver, remove the three screws from the battery.
    Ask FixBot
  5. Dell Chromebook 3110 Battery Replacement: step 5, image 1 of 1
    • Carefully lift the battery out of the laptop.
    Ask FixBot
To reassemble your device, follow these instructions in reverse order. For optimal performance, calibrate your newly installed battery after completing this guide.
4 other people completed this guide.
Anna K Tomko
178 Reputation
1 Guide authored
Marist, Team 1-6, Chaterdon Spring 2023 Member of Marist, Team 1-6, Chaterdon Spring 2023
MARS-CHATERDON-S23S1G6
2 Members
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 36
All Time: 1,421
