Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Sticking Buttons
You have an issue with you buttons staying stuck in the down position.
Buttons Stuck Under the Faceplate
If the buttons are stuck on your Coby Kyros attempt to move them around and get them to pop back up. If that does not work attempt to pry it up with a small object.
Cracked Touch Screen
Is the picture on the screen distorted, or obstructed by a crack?
Screen is Disconnected or has a Faulty Connection
See Coby Kyros MID7012 Screen Replacement.
Screen is Broken
Touch Screen Not Responding
Your touch screen is turning on but it is not doing anything when you touch it.
Unresponsive Display
If the screen on your Coby Kyros is frozen attempt to turn it off and back on again. If this fails attempt a hard reset using the reset button located on the back of the tablet.
Tablet Unresponsive
If your Coby Kyros is completely unresponsive attempt to turn it off and back on again. If it does not respond to the power button, attempt a hard reset using the reset button located on the back of the tablet.
Tablet Not Turning On
The tablet is off and is unresponsive when you press the power button.
Dead Battery
If your Coby Kyros does not turn on, the battery may be dead. Plug the tablet into the wall using the provided ac adapter. Wait 5-10 minutes and then attempt to turn the tablet on. If this does not work, attempt to use a different outlet to charge the tablet.
Stuck In A Power Cycle
If the Coby Kyros is still not turning on it may be stuck in a power cycle. Attempt to hard reset the tablet using the hard reset button located on the back of the tablet.
Faulty Battery
If the Coby Kyros is still not turning on then you may have a faulty battery that needs to be replaced. See Coby Kyros MID7012 Battery Replacement for replacement steps.
Poor Audio Quality
The Audio Is Distorted
Speaker has Faulty Connections
If the audio is not clear, the speaker may have a faulty connection. See the repair guide for the speaker.
Speaker Is Broken
If no audio is coming from the speaker, check to make sure that the audio volume is turned up and there are no headphones plugged into the tablet. If there is still no audio then the speaker may be broken, see Coby Kyros MID7012 Speaker Replacement.
Author
with
Daniel Ulrich
494 Reputation
3 Guides authored
IUPUI, Team 3-4, Harley Fall 2016 Member of IUPUI, Team 3-4, Harley Fall 2016
IUPUI-HARLEY-F16S3G4
4 Members
36 Guides authored
1 Comment
Kyros tablet
Can't establish a reliable connection to the server (IT IS CONNECTED TO MY WIFI )
This could be a temporary problem or your device may not be provisioned for data services if it continues call customer care
debdooo - Reply Share
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 23
All Time: 2,565
