Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Chromo Inc T2 Troubleshooting
Released September 2013.
Chromo Inc T2 won’t turn on
No matter what you do, you can’t get your device to turn on
Toggle the Power Button
Before we go any further in troubleshooting the device, press and release your power button three times to ensure the button is not sticking and that you feel the click. If there is no click, your power button is faulty, therefore the motherboard needs to be replaced. If this is not your problem, try holding down the button for 10 seconds. If none of these initially solves your problem, read on.
Drained Battery
If your tablet won’t turn on, check to make sure the battery isn’t dead after continuous use. Plug your tablet in through its corresponding cable to either a computer or AC adapter to see if anything happens. If it still does not turn on, your batter may no longer hold a charge and must be replaced with a new battery.
Faulty Screen
If you have already replaced the battery and the screen still does not turn on, your problem may be a faulty motherboard or your screen does not work. If your tablet turns on and gives a solid or distorted screen or remains black after replacing the battery, your screen will need to be replaced. If neither of these is the problem, then you may have a faulty motherboard that will need to be replaced.
No Sound or Distorted Audio
Everything else seems to be working with your tablet except, the audio doesn’t play back properly.
Distorted Sound from Chromo Inc T2
To ensure your internal speaker is the problem, try plugging your tablet into other sound playback devices such as speakers or headphones. If sound is working properly through either, then your internal speaker is bad and needs to be replaced.
No Sound
Toggle the volume button to make sure the device is turned all the way up. Make sure you feel a click as you press either the volume up or volume down button. If there is no click, then your logic board will need to be replaced. If this is not a suspected cause, try plugging in other audio playback devices such as speakers or headphones. If these work, then your internal speaker is faulty and needs to be replaced.
Faulty Front Camera
Everything else on your tablet works except for your camera
Camera will not turn on, not focus, or the screen is a solid color
Try restarting your tablet by turning it on and off. If this does not work, try going into your settings and updating software that may have interfered with your camera. If neither of these work, your camera is faulty and needs to be replaced.
3 Comments
Will not connect to Wi-Fi
Jennifer Jones - Reply Share
Did you get it connected? Mine won't turn on. What do I need to do
lschipman - Share
I can't get this thing to recognize ANY of my Bluetooth accessories, be they "ear buds", a keyboard, or speaker, not to mention my headset.
It doesn't matter if they're just "in the same room" or setting right next to it, NO JOY!
Any ideas out there?
Mike in Indy - Reply Share
