Chromo Inc. T2 Battery Replacement
  1. Chromo Inc. T2 Battery Replacement, Removing the Casing: step 1, image 1 of 3 Chromo Inc. T2 Battery Replacement, Removing the Casing: step 1, image 2 of 3 Chromo Inc. T2 Battery Replacement, Removing the Casing: step 1, image 3 of 3
    • Place your Plastic Opening Tool between the screen and the case. Slowly move it around the casing while prying in a downward motion to undo the hinges holding the two together and separate the two parts.
  2. Chromo Inc. T2 Battery Replacement, Turn it around: step 2, image 1 of 1
    • After separating the case and screen, turn your screen face down so you can see the internal parts!
  3. Chromo Inc. T2 Battery Replacement, Freeing the Battery: step 3, image 1 of 3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: step 3, image 2 of 3 Chromo Inc. T2 Battery Replacement, Freeing the Battery: step 3, image 3 of 3
    • Using the Spudger, going between the battery and screen, pry the battery off from the tablet.
    • Note: This will require a little extra force due to the tape holding down the battery!
  4. Chromo Inc. T2 Battery Replacement, Desoldering the Battery Wires: step 4, image 1 of 1
    • Using a Soldering Iron, desolder both Battery wires.
    • Soldering Iron gets very hot, take care to not touch anywhere on the soldering iron except for the handle!
  5. Chromo Inc. T2 Battery Replacement, Finished!: step 5, image 1 of 1
    • Your battery is now ready to be replaced!
2 other people completed this guide.
Ismael DeLuna
637 Reputation
5 Guides authored
USF Tampa, Team 15-1, Watkins Winter 2015 Member of USF Tampa, Team 15-1, Watkins Winter 2015
USFT-WATKINS-W15S15G1
4 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 20
All Time: 1,744
