Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
No Sound is Produced From the Keyboard
The keyboard won’t output sound or the sound quality is poor.
Left side of the keyboard does not output sound
Press the button labeled "ACCOMP" in order to the disable chord input in the accompaniment area of the keyboard. This enables the accompaniment function of the keyboard.
No sound is produced when a key is pressed
The volume might be turned to a low setting, try turning the volume up.
Check to see if there are any headphones plugged into the headphone jack.
If there isn’t a sampled sound in memory, nothing will be able to play if a tone within the range of 601 to 608 is selected.
Try turning the keyboard off and then on again so that the keyboard's settings are reset.
Continual Sound Output with No Input
Sound is continually produced, even when no keys are pressed on the keyboard.
Notes keep playing, even when no key is pressed
Turn the power off and on again so that the keyboard's settings are reset.
Try replacing the batteries (they might be dead) or switch over to AC adapter power.
Alternating Pressure Does Not Change the Sound Output
Pressing harder or softer on a key does not change the volume of a note played
The volume does not change even when the pressure applied to a key is different
Turn the keyboard off and on again so that the keyboard settings reset.
Audio Distortion
The keyboard sounds broken or disjointed
Sound quality is not consistent within different ranges of the keyboard
This is not a malfunction of the keyboard, but a limitation.
Octaves do not change at the far end of the keyboard
Display Does not Turn on Correctly
The LCD display is unusually dim, or does not light up at all.
Low battery
The battery power may be low. Try replacing the batteries with fresh ones. To do this, follow the Low Battery Guide
Faulty or broken screen
The screen may be broken, faulty, or otherwise unusable. In this case, replace the screen.
Power Failure
Keyboard will not turn on at all or will only stay on for a short time.
Dead or low batteries
Follow the Battery Replacement Guide.
Auto power off is triggered
If keyboard suddenly turns off after a few minutes, Auto Power Off is probably being triggered. The keyboard’s default is to automatically power off after 6 minutes if running on batteries. To disable this feature, when you turn on the keyboard for use, press and hold the TONE button (upper button to the right of LCD display) while turning on power.
Sticky Keys
The keys stick down when pressed or are harder than normal to push.
Contaminates under the key
When the key is harder than normal to push, there might be something stuck underneath the key. Try using compressed air to dislodge the contaminates. You can use quick blasts of air from different angles to thoroughly clean the underside of the key.
If the key is still difficult to press, you might have to remove the key and try and physically remove the contaminate. Once the key is removed, thoroughly clean the key with soap and water and then reinstall it.
Key is dirty
If a key is sticky, you might have to clean underneath it. To do this the key must be removed. Do this by following the guides for replacing White Keys and Black Keys. After removing the key, try using soap and water to completely clean it, then reinstall the key.
Failure of Computer Recognition
The computer does not do anything when the MIDI keyboard is plugged in .
Low battery
If the connection is choppy or weak, then the battery power may be low. Try replacing the batteries with fresh ones. Do this by following the Battery Replacement Guide.
MIDI/USB device has not been configured to the computer
Check to see if the MIDI/USB device has been configured with the computer. If it has not, or if you are unsure, connect the MIDI/USB device to the computer, load the device’s accompanying CD, and complete installation of the device.
MIDI cables are not plugged in and configured correctly
Ensure that all MIDI cables are correctly plugged in, so that the IN is plugged into OUT on the keyboard and OUT is plugged into IN on the keyboard. Ensure that these are correctly configured with the computer.
Local Control is turned off
Turn on Local Control on the keyboard.
Author
with
liam Mora
4 Reputation
0 Guides authored
Cal Poly, Team 10-2, Banghart Winter 2017 Member of Cal Poly, Team 10-2, Banghart Winter 2017
CPSU-BANGHART-W17S10G2
4 Members
72 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 30
All Time: 2,674
