Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Quadrocopter Will Not Power On
The Quadrocopter will not respond or power on.
Battery Cord Is Not Connected
Connect the male and female ends of the battery cord and the socket on the underside of the Quadrocopter.
Battery Is Dead
Plug one side of the USB charging cable into a computer and the other into the battery cord. Let the battery charge until the LED display on the USB charging cable lights up green. The battery is now fully charged. Disconnect the battery from the USB charging cable and reinsert it into the Quadrocopter.
Battery Is Damaged or Faulty
If the battery is fully charged and the battery cord and socket are connected, please consider replacing the battery.
Remote Will Not Power On
The remote will not respond or power on.
Power Switch Is Off
Ensure that the power switch has been pushed upward into the ON position and the control LED light on the top center of the remote glows red.
Batteries Are Not Properly Installed
Attach the PH1 head to your screwdriver and unscrew the battery cover. Make sure that there are six AA batteries and that the positive and negative charge symbols on the batteries match the symbols on the remote.
Batteries Are Dead or Faulty
If the power switch is on and the batteries are properly installed but the remote still won’t power on, please consider replacing the batteries.
Propellers won't spin
You have trouble getting the propellers to spin.
Propellers are damaged or stuck
Ensure that the device battery is charged, and the propellers are not broken. If the propellers are broken, consider replacing the propellers with new ones. If the propellers are in good shape or new and the device still does not fly, consider checking the gears. Make sure they are not stuck or broken.
Foam is damaged or broken
If the device foam is broken, the device will be unbalanced when flying and might fall off.
If the break in the foam is small, consider taping it to cover the break and trim the device. This way the device will balanced properly when flying. Otherwise, consider replacing it.
Device doesn't respond to remote
Your Quadrocopter will not respond to the controller.
Controller is Off
Check your controller to make sure it is on. If not, flip the switch to turn it on. This can be confirmed by a single beep when it turns on.
Quadrocopter is Off
Check your device if the battery is plugged in. You may have to connect the battery to the device. If the battery is not charged you will have to do so. If the battery is damaged, you may need to replace the battery.
Controller and Quadrocopter are Not Frequency Bound
The controller and quadrocopter are frequency bound at purchase. If there are any problems try these steps: Turn the controller off and disconnect the battery from the device. Reconnect the battery and the LEDs on the device should now flash rhythmically. Turn the controller on. Push the left-hand joystick straight to the top, then straight down. This should successfully bind the controller and device and can be confirmed when you hear 2 beeps with the light being continuously on.
Battery of device won't charge
The rechargeable battery will not charge.
Incorrect USB Charger
Please only use the USB charger provided by the manufacturer. It can be found in the product package. If the charger wire came with the copter doesn’t work, it might be defected or it has reached product life. Switch to the replacement USB wire charger.
Fail connection between charger and computer
Check to see if you plugged the charger wire to the correct USB port instead of the eSATA port. Test with multiple USB ports on your computer until there is a message “your device is ready to use” at the bottom right corner of your screen if you have Windows system. If you have Mac Os sytem, go to Finder then scroll to the Device section and locate the device name Carrera Mario Copter. The LED on the USB charger will turn light green indicating that the charging unit is correctly connected to the computer.
LED doesn't light up while charging
Wait for 60 minutes for device to charge. Once the battery finished charging the LED on USB will light up green again. Keep in mind, the LED will not light up during the process of charging.
Author
with
Edgar Lopez-Allende
207 Reputation
2 Guides authored
UW Tacoma, Team S1-G6, Rose Fall 2017 Member of UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 Members
60 Guides authored
10 Comments
but how do you know if the battery is properly charging if you don’t have any light signals. And can we charge the batery only by comptuer or also we can use other phone charger heads?
albanbislimaj - Reply Share
I can t remove the battery from charger just bought yesterday & now its to hard to remove…how can i remove from charger thank you
afnunez68 - Reply Share
When I release flying Mario, it spins and goes straight to the ground. What is the correct way to remedy this.
Dave Bussard - Reply Share
Mine does this too! Did you fix it?
Joshua Taylor - Reply Share
I have the same problem, it spins but doesen’t fly and falls to the ground
Emilio Curci - Reply Share
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 92
All Time: 11,469
