Carrera Mario Copter Rotor Blade Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
6
Past 7 Days:
23
Past 30 Days:
102
All Time:
2,149
Comments: 1
1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 seconds
Difficulty: Easy
Introduction
Go to step 1 ↓
The quadrocopter will not fly correctly if a rotor blade is damaged or installed wrong. This guide will show you how to remove any of the quadrocopter’s four rotor blades.
Tools
    1. Carrera Mario Copter Rotor Blade  Replacement, Rotor Blade: step 1, image 1 of 1
      • Using the JIS #00 screwdriver, hold the rotor blade still and unscrew the 4.762mm screw in the center of the blade.
      Ask FixBot
    2. Carrera Mario Copter Rotor Blade  Replacement: step 2, image 1 of 1
      • Lift the screw out and set it aside.
      • Lift the rotor blade out.
      • Be sure to place the rotor blades properly for stable flight. With the quadrocopter facing you, the front rotor blades should be red with blade A on the right and B on the left. The rear rotor blades should be blue with blade B on the right and A on the left.
      Ask FixBot
Marissa Espino
128 Reputation
1 Guide authored
UW Tacoma, Team S1-G6, Rose Fall 2017 Member of UW Tacoma, Team S1-G6, Rose Fall 2017
UWT-ROSE-F17S1G6
4 Members
60 Guides authored
1 Guide Comment
Hi. How i can buy the rotor blade
Ainul Abd Rahim - Reply Share
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 102
All Time: 2,149
