Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
“Lens Error Restart Camera” message
The camera screen gives an error message that says, "Lens Error Restart Camera"
The shutter and/or lens is stuck.
If the shutter and/or lens is physically stuck in an open position, grit or other physical obstruction may be blocking the shutter. Use compressed air or a hair dryer on the cool setting to clear the obstruction.
Camera was dropped or shut down while the shutter was open or lens was out.
Try restarting the camera. If this doesn’t resolve the issue, try replacing the lens.
Screen is Not Coming On
Dead battery
Make sure your battery is fully charged and the battery door is properly closed. If this does not resolve the issue, replace the battery.
Bad logic board
If the camera has water or impact damage, a circuit on the logic board may go bad. Make sure your battery is fully charged. If your camera still will not turn on at all, with no lights or display coming on, this is likely the case. Replace or repair logic board.
Broken or cracked LCD screen
If the screen is broken or cracked, but the device still powers on, replace the LCD screen.
Distorted Color or Image on the Screen
Camera was exposed to liquids or extreme temperature
Try restarting the camera. If this does not resolve the issue replace LCD Screen.
Camera was dropped or screen was otherwise damaged
If the screen is broken or damaged, replace LCD Screen.
Malfunctioning Flash
The camera flash is not working properly or at all.
No flash
Check the camera settings and make sure the flash is turned on.
Make sure the battery is fully charged. A low battery may affect the flash function. If charging the battery doesn't resolve the issue, the flash unit is likely faulty. Replace the flash.
Delayed flash
Check the camera settings and make sure the self-timer isn't selected.
Camera Won’t Read Memory Card
The camera does not recognize the inserted memory card.
The memory card or memory card slot needs to be replaced
Make sure the battery is fully charged and the memory card is inserted properly.
Try the memory card in another device to see if it is functioning properly. If it does not work in another device, try replacing the memory card.
If the memory card works in another device, the problem is likely the memory card slot.
Camera Not Charging
The camera or battery is not charging when connected.
Malfunctioning charger
If the indicator lights on the charger are malfunctioning or behaving strangely this may indicate that the problem is with the charger. If you think this is the case, unplug the charger from the wall immediately and do not plug your battery into the charger. Inspect the charger for damages; do not use if you can see physical damages to the charger or cord because of risk of fire. Replace the charger.
Malfunctioning battery
Make sure the battery door is closed properly or the camera won't charge. If this doesn't resolve the issue, replace the battery.
0 Comments
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 22
All Time: 1,512
