Introduction
Many camera problems can be fixed by replacing the LCD screen. If your screen is visibly cracked or broken or has been damaged due to impact or exposure to liquids, replacing the LCD screen may resolve your issues.
Close the battery door, and turn the camera over so that the bottom of the camera is facing up.
Using a PH000 screwdriver, remove the two 5.5mm screws.
Carefully slide out the LCD screen from the back part of the casing.
You should now have three components: The back of the LCD screen casing, the LCD screen, and the front of the LCD screen casing.
The LCD screen is now removed and can be replaced or set aside to access other camera components.
3 other people completed this guide.
