Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not turn on
No matter what you do, you can't get your camera to turn on
Drained/bad batteries
If your camera will not turn on the most likely reason is that your batteries are drained or bad. Try replacing the batteries.
Zoom lens will not extend/retract properly
The camera will turn on but the zoom lens will not extend properly.
Camera was interrupted while powering on/off
If your camera was interrupted while powering on or off it may not have been able to properly extend or retract. Check that your batteriesare secure and not drained/bad and try restarting your camera.
Zoom lens rings is damaged
Physical trauma to the camera can cause damage to the zoom lens ring, preventing extension of the zoom lens. Zoom lens ring damage is very common. Try replacing the zoom lens ring.
Battery door will not close
The battery door will not close or will not stay closed.
Battery door is damaged
If the battery door of the camera will not close or will not stay closed it may be damaged. Check that the door is free of debris and that there is nothing obstructing it. If the battery door still will not close or stay closed try replacing the battery door.
Camera will not take picture
The camera is physically unable to take a photo or the camera will take a photo but is unable to save it and/or an error message is produced.
Memory card is full
If your camera will not save a photo and/or an error message is produced your memory card may be full. If the memory card is full you can delete images or replace the memory card.
Memory card is damaged
If your camera is unable to save images and/or an error message is produced your memory card may be damaged and need to be replaced.
Memory card is locked
The memory card may be in the locked position. Check to make sure the switch on the memory card is not is the locked position.
Trigger button is jammed or damaged
If you are pressing on the trigger button but the camera will not take a photo, the shutter button may be jammed or damaged. Check for debris or try replacing the trigger button.
LCD screen not displaying
The LCD screen is black or not properly displaying images.
LCD screen is damaged or broken
The LCD screen may be damaged and unable to display images. Try replacing the LCD screen.
Alicia Burns
645 Reputation
5 Guides authored
Clemson, Team 2-5, Benson Fall 2014 Member of Clemson, Team 2-5, Benson Fall 2014
CLEM-BENSON-F14S2G5
4 Members
108 Guides authored
3 Comments
When taking a video the picture won’t show when playing it on my laptop with the memory card
Mike - Reply Share
Says “no memory card" when memory card is installed and unlocked. How do I fix this?
rault2120 - Reply Share
My memory card is 64gigs, can the camera not handle that? it is also a micro sd card with an sd card adapter, does this not work with it?
Anna - Reply Share
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 47
All Time: 3,063
