Student-Contributed Wiki
An awesome team of students from our education program made this wiki.
Camera will not turn on
You cannot get the camera to turn on.
On/Off button needs to be pressed firmly
Start by pressing firmly on the on/off switch. If the camera does not turn automatically, it may need the power switch replaced. If the power switch is not broken, read below.
Drained/Bad Battery
Your camera may need a charged battery or a battery replacement. Begin by charging your camera normally. If the camera does not turn on with the charged battery, you might need a new battery. The Battery Replacement Guide will help you with this.
The LCD Display is not working
Your camera may actually be on but the LCD display is malfunctioning. Refer to the LCD replacement guide to fix this.
Motherboard needs to be cleaned/replaced
The motherboard can cause problems. It could have short circuited, needs to be cleaned, or something could have malfunctioned on the board. The motherboard should be replaced.
E18 Error displays on screen
E18 Error displays on LCD screen.
Battery drained/Low battery
Replace the batteries. Refer to the Battery Replacement Guide for more assistance.
The lens has dirt/sand particles that will not allow it to function
Use compressed air to attempt to dislodge the particle. If that does not work or you do not have compressed air, you can attempt to remove the particle using a piece of paper.
Camera needs to be factory reset
Follow the steps in the user guide to start a factory reset on the device.
Short battery life/Battery errors
The camera loses power quickly after powering on.
Drained/Bad battery
The battery may be drained due to excessive use or improper charging. The battery will need to be replaced. Refer to the battery replacement guide for assistance.
Poor Electrical Connections
Electrical connections from the battery to the rest of the camera may be corroded. This can be caused by high humidity levels in the air. In order to enhance the electrical connections, the camera will need to be taken apart. Any electrical connections and wiring will need to be checked for corrosion and cleaned.
Cracked/Damaged LCD Display
The display has an obvious crack on it or damage.
LCD needs to be replaced
The device will need to be disassembled to replace the LCD display. Make sure the device is turned off before removing the screen. Replace the screen with a new LCD display and reassemble the camera. Use the LCD Display Replacement Guide for help with disassembly.
Camera will not flash
This may be due to a deactivated flash setting on the camera or it may require a replacement for the flash assembly on the camera
Deactivated Flash Setting
To ensure that the setting is activated, press the right arrow button again. The flash will automatically fire in low-light conditions as well so take it somewhere dark and attempt to take a picture to test if the flash is working properly.
Flash Assembly Malfunction
The flash assembly will need to be replaced. Use this guide to assist with the disassembly of the camera.
Jose Garcia
35 Reputation
0 Guides authored
USF Tampa, Team 1-1, Sullivan Winter 2015 Member of USF Tampa, Team 1-1, Sullivan Winter 2015
USFT-SULLIVAN-W15S1G1
3 Members
48 Guides authored
2 Comments
My speakers don't work
Azmatullah - Reply Share
LE MESSAGE INDIQUE : AUCUNE IMMAGE ALORS QUE JE SAIS AVOIR PRIS BEAUCOUP DE PHOTOS
merci pour votre aide !
LEONIE - Reply Share
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 21
All Time: 2,344
